Franken-bike lives, and works! Dead easy to lock up back wheel, even with coaster brake, given the lack of weight on the back end. Now all I need to do is "make" a seat and rack.
Note indexed shifter, bargain tandem gear cable, exquisitely [s]machine[/s] angle-ground detail.
[url= http://farm3.static.flickr.com/2037/5742180753_ee3f34af58_z.jp g" target="_blank">http://farm3.static.flickr.com/2037/5742180753_ee3f34af58_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/7693620@N05/5742180753/ ]IMAG0538[/url] by [url= http://www.flickr.com/people/7693620@N05/ ]alan cole[/url], on Flickr
Presumably you've used such a bad photo to make sure no companies can copy your design?
You are king o bodge and I salute you. I had thought of doing something similar once but didn't come up with the seat post solution like you. Did you just drill a hole though the rear frame to do that or does it clamp as well? Is it just a very long chain as well? Truly awesome
Awaits the words of 'the master'
If it works out I can see a similar bike being made one day in Drogheda 🙂
Rik it's 3" of the 31.6 seatpost off the rear frame, split to get out to 27.2 internally for the front post, inserted to a hole drilled/filed in the top tube, it's a tight fit bu I've araldited it in (curing as we type) and I have a clamp to go over the top top (probably not needed). It's a mix of older chains 😎
You got a better picture of it?
[url= http://farm5.static.flickr.com/4005/4540060923_9a266dbff0.jp g" target="_blank">http://farm5.static.flickr.com/4005/4540060923_9a266dbff0.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/willevans/4540060923/ ]IMG_4259[/url] by [url= http://www.flickr.com/people/willevans/ ]gatechcycling[/url], on Flickr
is this the sort of thing your building , hard to tell from your pic but looks similar to this one
looks interesting and this one intrigues me better pic please
what is this for?
[url= http://farm1.static.flickr.com/182/440268085_d2cc5e37e1_z.jp g" target="_blank">http://farm1.static.flickr.com/182/440268085_d2cc5e37e1_z.jp g"/> ?zz=1[/img][/url]
[url= http://www.flickr.com/photos/kstoerz/440268085/ ]IMG_1903[/url] by [url= http://www.flickr.com/people/kstoerz/ ]kstoerz[/url], on Flickr
[url= http://farm4.static.flickr.com/3647/3464232086_e273afb447_z.jp g" target="_blank">http://farm4.static.flickr.com/3647/3464232086_e273afb447_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/cameronbicycles/3464232086/ ]Chase S. Longtail Conversion[/url] by [url= http://www.flickr.com/people/cameronbicycles/ ]Cameron Bicycles[/url], on Flickr
[url= http://farm4.static.flickr.com/3442/3379785687_1c04698ca8_z.jp g" target="_blank">http://farm4.static.flickr.com/3442/3379785687_1c04698ca8_z.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/bikeman04/3379785687/ ]Bike frame extension[/url] by [url= http://www.flickr.com/people/bikeman04/ ]xddorox[/url], on Flickr
[url= http://farm4.static.flickr.com/3406/3307385877_3d0056ac04_z.jp g" target="_blank">http://farm4.static.flickr.com/3406/3307385877_3d0056ac04_z.jp g"/> ?zz=1[/img][/url]
[url= http://www.flickr.com/photos/9350817@N07/3307385877/ ]extra16[/url] by [url= http://www.flickr.com/people/9350817@N07/ ]harvwoien[/url], on Flickr
I must say that I am liking this idea. I also have a number of old frames kicking about that would be just the ticket.
The deathrap tandem looks quality too.
Will do a better pic - see my other thread, taka's pic of his version is on it.
looks very interesting - a better pic would be good. 🙂
here it is in action. Rides well, front end a bit low though (its used to 450mm forks not 400mm!)
[url= http://farm6.static.flickr.com/5301/5750703061_c5cc843f83_z.jp g" target="_blank">http://farm6.static.flickr.com/5301/5750703061_c5cc843f83_z.jp g"/> [/img][/url]
[url=
Daddy?...
Yes, son...
Why's that green bike playing piggy back rides with the grey one?...
[i]here it is in action.[/i]
As long as it's always d-locked to a Sheffield stand when you use it you'll be fine 😉
it's a good job there's no construction and use regulations for bicycles, but fair play to you for some proper bodging.
I hope that's not a Mongoose Transfer you've chopped up? (If you need another one, let me know!)
While I'm here, I may as well ask........... er......... what's it for?
Stu - next time, I'm working on FS fat for now...what are you doing?
Paul, it's for "fun" (if you know what that is), will get a rack and seat for ute-bike duties in time.
Ok, that's fine, yes I know what 'fun' is, don't worry. It just wasn't immediately obvious why you'd done it as it appears to serve no practical purpose as it is. Carry on.....
