Yeti ASR5 disc brak...
[Closed] Yeti ASR5 disc brake set-up (Formula RX) discs seem too small?!?
10 Users
I've just installed a set of Formula RX discs on my Yeti ASR. the front is running a 180mm post mount with a Alligator Cutter 180mm disc. The rear is running a 160mm IS mount with a 160mm Alligator Cutter disc.
The rear disc seems to small small for the caliper & mount (ie. not very much of the disc is actually being gripped by the pads) and the front is better, but still only contacting with 70% of the braking area.
What am I doing wrong?
Posted : 01/05/2012 12:21 pm
not sure, but I have a Formula RX brakes on my ASR5 and they fit perfectly. That is with a 180mm rotor on the rear, mind.
Posted : 01/05/2012 12:26 pm
Is it all new kit? the front has nothing to do with your choice of frame - so i'd imagine if it fit before, it will fit again! (if that makes sense)
Posted : 01/05/2012 12:27 pm
i'm wondering whether it is something to do with the rotors... anyone with experience of alligator windcutters?
Posted : 01/05/2012 12:29 pm
sure your old rotors weren't 185mm, and your mount adaptor is the same?
Posted : 01/05/2012 12:31 pm
nope... new rotors, new callipers, and the mounts both say 180mm & 160mm on them... the mounts are the correct way up and are front & rear specific.
Posted : 01/05/2012 12:41 pm
all part of the same kit? or bought seperately?
take some pics and post them up - might help!
Posted : 01/05/2012 12:42 pm
pics?
looking at this carefully, only about 2mm of the inside bottom circular section of the rotor is not making contact, so I guess that is almost acceptable
this on the other hand quite clearly shows that only 50% of the braking surface of the rotor is meeting the pads (and due to the windcutter shape, it is the bladed section rather than a regular circular section
Posted : 01/05/2012 12:58 pm
You sure it's a 160mm rotor?
Posted : 01/05/2012 1:00 pm
try the rear adapter the other way around.
Posted : 01/05/2012 1:02 pm
 P20
Wwaswas. Thats what I thought
Posted : 01/05/2012 1:07 pm
the arrow on the back of the adapter is pointing upwards...
Posted : 01/05/2012 1:17 pm
even so.
Posted : 01/05/2012 1:18 pm
will give it a go... i guess i can put a spacer or two between the mount and the caliper if it fouls slightly... but if it does work, surely the pads will be angled incorrectly against the disc?
Posted : 01/05/2012 1:20 pm
I'm pretty sure on my RX rear adapter the side with the size marked on it faces outwards which would suggest this one could be fitted the wrong way round.
Posted : 01/05/2012 1:25 pm
i'm not using a formula mount on the back as i only have a 180mm version
Posted : 01/05/2012 1:50 pm
I would be surprised if the logos were on the outside rather than facing the wheel
Posted : 01/05/2012 2:40 pm
[i]I would be surprised if the logos were on the outside rather than facing the wheel [/i]
why, the front mounts that way?
Posted : 01/05/2012 2:55 pm
so is it not a 165mm mount then if it isn't the formula one?
Posted : 01/05/2012 3:12 pm
Any luck?
Posted : 03/05/2012 1:17 pm
Is the mount for a front brake? The front one says F-180 on it - does the rear say R-160? If it says F-160, there's your problem.
EDIT: Ignore. A front 160mm adaptor would be too small, rather than too big.
Only a few possibilities left. What size is the rotor? [i]Definitely[/i] 160?
Posted : 03/05/2012 3:32 pm
Or the wheel isn't sat in the dropout correctly 🙂
Posted : 03/05/2012 4:08 pm
