Hey folks. ive got an AS R-5 with quick release on the rear, ive got hope pro 2 hubs and im wanting to convert it to 142 x 12.. what components do i require to do this?
All the following which imo there are better things to spend the best part of £100 on?
[url= http://www.merlincycles.com/hope-pro2-evo-rear-hub-axle-conversion-kits-54057.html ]Hope conversion kit[/url]
[url= http://yetifan.myshopify.com/collections/yeti-as-r-5-all-models/products/142x12-chip-kit-only ]Yeti chip kit[/url]
[url= http://www.chainreactioncycles.com/shimano-xtr-trail-e-thru-rear-axle-m988/rp-prod54897 ]Shimano axle[/url]
Much cheaper axle:
http://www.rosebikes.co.uk/article/shimano-sm-ax55-thru-axle-for-e-thru-system/aid:670710
But the price of the chip kit is still pretttty steep.
Hi, ive got a used chip kit for the yeti its yours for £40 with the axle.
If you hub is pro 2 you will need the x 12 kit crc do them.
If pro 2 evo you will just need end caps.
Can I slightly hijack this and ask the question: Is there a large Allen headed bolt I can use instead of the Shimano 142mm QR axle? I find the qr lever gets in the way of the brake area on my SB95.
