xx44 Taped Headset
[Closed] xx44 Taped Headset
3 Users
Afternoon all
I want to change my forks on my XX44 headset (genesis alpitude) to a tapered steerer, from a straight steerer. I tried fitting them in (as I thought the reducer was on the fork rather than the cup) but they didn't fit. Can someone show me a headset that will fit? I guess the cup needs to be basically non existent because the current is fairly low profile, however it still didn't fit.
cheers!
Posted : 19/04/2014 4:57 pm
You need to change the bottom cup from ZS44/30 (1?" zero stack) to EC44/40 (1.5" external). Top cup should be fine.
Posted : 19/04/2014 5:23 pm
Perfect explanation, thank you.
http://www.evanscycles.com/products/cane-creek/40-series-ec44-bottom-headset-ec026967
Gonna go for that, will move the bearings outside the frame which makes sense. Evans because I can pick it up tomorrow.
Does anyone know of a 'low stack' top cap? I have an FSA on the top which is about 12mm or something, I need a low stack one as the steerer is a bit short. By 'top cap' (I got the wording from the hope PDF but not sure) I mean the compression part which squeezes the bearings into the cup.
Posted : 19/04/2014 6:02 pm
 nc21
Recently did this on my Latitude with a Reba tapered fork. Had a Cane Creek top cap which was reused with a new bearing. Sorry cant give codes - bike in LBS to have new mech hanger sourced and fitted
Posted : 19/04/2014 8:23 pm
All sorted thanks, picked up the bit this morn and fitted, runs perfectly.
Posted : 20/04/2014 6:26 pm
