XX1 Chainring wear
[Closed] XX1 Chainring wear
7 Users
Has anyone else experiencing extremely rapid chain ring wear with XX1? I have ridden less than 500 miles since I got my bike in November and its making a grinding noise as the chain is not leaving the bottom of the chainring smoothly.
I showed it to a bike mechanic friend and he laughed saying the chainring was worn and thats what you get for going SRAM! A replacement from CRC is 70 quid and due to the bolt pattern you must use SRAM parts... I have a Race Face Narrow Wide on 2 other bikes with no such issues so I can't see any reason for this other than a deliberate way to get more money out of you every few months.
Posted : 10/02/2014 11:10 am
Blackspire seem to do an XXI-compatible Narrow/Wide ring for less cash
http://www.chainreactioncycles.com/blackspire-mono-veloce-xx1-narrow-wide-chainring/rp-prod112088
Posted : 10/02/2014 11:18 am
If you look around you can get other chainrings that are sram compatable.
I'm pretty sure a guy I know has one of these:
[img] ?v=1387506380[/img]
But 500 miles in a wet winter [i]could[/i] destroy a lot of parts.
Posted : 10/02/2014 11:19 am
I've used them all year and no problems with wear.
They make a noise in the mud, but thats because they hold the chain tightly.
Depends where you are riding to an extent. Certain soil will increase the speed it wears.
Posted : 10/02/2014 11:20 am
You could also remove the spider and use a spiderless ring like absolute black, works or wolf tooth. Saves a bit of weight as well 😉
I don't believe the options above are compatible, they are just XX1 copies.
Yeah I suppose I have been out in some pretty nasty conditions but then so have the other bikes...
Posted : 10/02/2014 11:44 am
Are you cranks like these:
Posted : 10/02/2014 11:48 am
Yes, I see now how they are fitted! Cheers!
Posted : 10/02/2014 11:50 am
What's the difference 😕
Posted : 10/02/2014 11:53 am
The bolt pattern
Narrow/Wide do pick up quite a lot of debris which can cause some issues so its a good idea to clean them regularly.
Are you sure its the chainring though? If the clutch/roller-bearing in XX1 rear mechs gets stiff it makes the noise you describe. The roller-bearings are not well greased; the two I have had required the bearing to be greased once they started making the noise you describe.
[url= http://bicyclingaustralia.com.au/2013/08/sram-type-2-overhaul ]Linky[/url]
If it really is chainring wear you should be able to see it, and if it has happened in the that milage I would be returning it to SRAM. Mine is fine with more milage on it.
Posted : 10/02/2014 12:05 pm
I will check this out tonight, I can see the the chain sticking to the bottom of the chainring and it only happens under load going up steeper climbs. Would that be similar symptoms you experienced?
Posted : 10/02/2014 12:23 pm
Yes - and there is a stickyness to the movement of the mech when you push it forward, like a hesitation and then it moves. I think this hesitation/friction means the chain is not pulled off the chainring teeth cleanly causing the noise and unpleasant feeling.
Both of the ones I have used stopped doing it after greasing the roller-bearing as per the link.
Word of caution - the roller bearing cap is plastic and easy to crossthread when re-fitting... you don't want to tear out the threads.
Posted : 10/02/2014 12:29 pm
