XTR V brake stickin...
[Closed] XTR V brake sticking
2 Users
I've not used them for ages, but I had a problem where the rear callipers would stick on.  The bike shop would clean them up, but it didn't seem to do much good.  They were on a fixie, and I didn't need to use the rear brake, so lack of use might have been part of the problem. Once they started to stick I'd just release the cable.
Anyway, I might be pressing them into service again on a new frame!  Is there anything which can be done to service them?  I've read that Shimano used to have a service kit for the XTR brakes.  They're the blue-y grey ones, with the parallel linkages.
Failing that, should I try to buy a 'new' pair, or are there any current V-brakes which are as good or better?
Posted : 23/03/2018 4:25 pm
Check the obvious first i.e. frame mounts clean and lubed, cables run freely including noodle, linkages clean/lubed and are moving nicely and pads are adjusted to hit the rim squarely and not lipped or catching under rim. XTR Vs are normally damn good.
Posted : 23/03/2018 4:39 pm
Thanks for that. Yes, I was just thinking they might be fine on a different frame, so I'll give them a clean up before installing them.
Posted : 23/03/2018 4:48 pm
