XTR SL-M980 10 spee...
[Closed] XTR SL-M980 10 speed lever - Is it fixable?
2 Users
Hi helpful stw'ers,
I bought an XTR SL-M980 10 speed lever second hand and there is a lot (maybe 10mm) of up and down play in the shifter lever (the one that shifts into easier gears).
Is there anyway to fix this? I opened up the lever and couldn't see anything obvious, I didn't want to poke around too much incase I couldn't re-assemble it.
Thanks in advance for any help!
Posted : 29/08/2019 3:01 pm
I am always prepared to try to fix anything but I must say that shifters flummox me. Are all the screws tight? It sounds like a pivot has come loose.
Posted : 29/08/2019 4:22 pm
All the screws that hold the case together are tight, I'm not sure if there are any other screws or bolts inside that could be tighter...
Posted : 03/09/2019 10:34 am
Removing the outer casing is easy enough. Perhaps do it in a big polythene bag to catch any potential loose bits. Once removed you can inspect the spring loaded wizardry within and nip up any loose screws etc.
Posted : 03/09/2019 10:57 am
This is my issue, can these things actually be taken apart and reassembled? If there is something that can be tightened then it's underneath the springs and stuff and I think it'll never go back together if I take it apart!
Posted : 03/09/2019 11:30 am
