XTR shorter + Saint...
[Closed] XTR shorter + Saint shifter = Heavy shift?
4 Users
Hi all,
I just moved over to 10 speed and have encountered something unexpected. I was running 9 speed XTR 970 shifter with a saint mech on a sram PG990 32t cassette. It was awesome but I have a another bike that could do with it.and fancied the extra gear that an 11-36 would give me and the benefits of the clutch mech. I have replaced it with an XTR 980 shifter, a new saint mech and an XT cassette. I know pull ratios of 10 speed are different but the shifting is really heavy, even with the clutch off.
Is this normal or is something sounding off?
John
Posted : 14/02/2014 7:56 pm
Sounds wrong to me, the 980 shifters I've used have been so light you'd think the cable was broken- horrible.
Posted : 14/02/2014 10:02 pm
They are heavy with the clutch mech turned on , super light like 9 speed version when clutch is off, on both my bikes 😀
Posted : 14/02/2014 10:25 pm
Perhaps the clutch needs adjusting? - i have the same set up as yourself but i use a zee clutch mech and the action is silky smooth, even with the clutch switched on and with the clutch switched off it can change by the power of thought, have a google on how to adjust the clutch mechanism and make sure it is lubed, a piece of piss to do this, all clutch mechs have a heavier pull when the clutch is on as it limits the free movement of the Derailleur arm btw.
Posted : 14/02/2014 10:41 pm
Awesome, well I will strip it apart tomorrow and investigate further. I don't think Exeter weather will be allowing for any outings anyways. I did see something about adjusting the clutch band on t'internet so will give it a go. Also just realised my phone kindly auto corrected shifter to shorter, if any mod would be so kind as to change the title so I don't look like a moron that would be appreciated!
John
Posted : 14/02/2014 11:18 pm
