XTR Short Cage conv...
[Closed] XTR Short Cage conversion.
5 Users
I am led to believe that I can convert my 08 XTR Shadow rear mech to short cage by using[url= http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/RD/EV-RD-M810-2830D_v1_m56577569830676104.pdf ] Saint M810 parts.[/url]
Before I order the bits, has anyone actually done this?
Thanks.
Posted : 31/05/2011 8:08 pm
 GW
cut the cage plates down, drill new holes for the tension pulley and use a nut n bolt to hold it.
Posted : 31/05/2011 8:13 pm
Not done this but having fiddled with other mechs I can say that the spring (part 8 in your pic) is a bugger to get back in.
Interested to see if it can be done though, I've got two long-cage shadows I'd like to swap for shortcages.
Posted : 31/05/2011 8:17 pm
GW - is this something you have done or just theory?
Posted : 01/06/2011 5:41 am
Found this the other day when I was contemplating the same:
[url= http://www.sicklines.com/2009/06/30/a-sicklines-custom-xtr-m972-short-cage-derailleur/ ]clicky[/url]
hth
Posted : 01/06/2011 6:26 am
I take it you mean part 6?
The trick with those is to give yourself a 3rd hand by clamping the relevant size hex key in a vice
You can then drop the mech on the hex key and tension it with one hand whilst putting the circlip on with the other
Posted : 01/06/2011 6:48 am
 GW
seen it done more than once, it works just fine.. in fact a mate has been running a shortened mech cage (unintentionally shortened 😉 ) with no lower jockey wheel on his DH bike for over a year with no issues.
Posted : 01/06/2011 10:01 am
