XTR M970 Chain ring...
[Closed] XTR M970 Chain rings - whose are compatible other than Shimano?
10 Users
Middle ring specifically at the moment but will need to replace others at some point.
Thanks
Posted : 04/06/2013 11:55 am
M970 middle and outer rings are pretty much standard. The inner ring has a custom offset but you can replicate it with a normal ring and some spacers (one of mine has a Works single ring on it, the other has an SLX inner and a deore steel middle 😉 )
Posted : 04/06/2013 11:59 am
I just use any 4 bolt ring. For the granny ring you need to use 2mm washers/spacers though as the standard XTR one is dished.
Posted : 04/06/2013 12:00 pm
Granny ring for xtr isn't any more expensive than others really.
Posted : 04/06/2013 12:03 pm
Middleburn do direct replacement for half the cost of XTR no need to faff with washers or spacers.
Posted : 04/06/2013 12:18 pm
Yeah, but then you have Middleburn rings.
You can use anything you want on the middle/outer. The only thing special about the Middleburn ones (aside from the offset inner) is they match the profile of the spider.
Posted : 04/06/2013 1:16 pm
davidxbrown - Member
And the only downside will be the inferior shifting and fast wear rate- win!
Posted : 04/06/2013 1:24 pm
Agree shifting not quite as good but wear rate in my experience is the same, I would buy again.
Posted : 04/06/2013 8:25 pm
imo avoid the middleburn rings on a double or triple - they are pretty crap in my experience
Posted : 04/06/2013 8:43 pm
THIS
It is true middleburn dont shift as well as i have one on my double and bash
Expensive for XTR rings as a set though
Posted : 04/06/2013 8:49 pm
I had to replace a middle and inner a few weeks ago, bike discount.de were the cheapest at £14 for the inner and £63 for the middle - it still hurt but cheaper than anywhere else!
Iain
Posted : 04/06/2013 10:06 pm
Just replacing my inner and middle.
I've gone
[url= http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_919847_langId_-1_categoryId_165545 ]Halfords for inner[/url] free delivery to store.
And
[url= http://www.tweekscycles.com/components/mtb-chainrings/shimano-deore-xt-m770-replacement-9-speed-chainrings ]Tweeks for XT M770 32t middle[/url]
Which should be a straight swap/fit
Posted : 05/06/2013 6:19 am
