XTR crank removal (...
[Closed] XTR crank removal (and BB30)
3 Users
Time to replace the BB on my Whippet (bought SH last year). However I can't work out how to remove the left crank arm to start the process- the extraction ring thing which should sit in around the large bolt isn't there. Any ideas of a way round this??
While I'm here, removing the BB and replacing seems fairly simple with the right tool, is it really just a case of knock it out and knock the new one in?
Posted : 01/03/2014 4:45 pm
 IA
M970 xtr?
You got the extractor tool?
If not, go get one. If you have, what you say doesn't make sense, got pics?
If it's newer XTR I can't help, sorry.
Posted : 01/03/2014 4:51 pm
I don't have the extractor tool, I wasn't sure if I needed it so thought I would look/ ask first. Not sure on which model the cranks are I'm afraid!
This is what I have....
[url= http://farm8.staticflickr.com/7344/12858751624_f062be1018.jp g" target="_blank">http://farm8.staticflickr.com/7344/12858751624_f062be1018.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/77208531@N02/12858751624/ ]Untitled[/url] by [url= http://www.flickr.com/people/77208531@N02/ ]northdownsouth2012[/url], on Flickr
[url= http://farm4.staticflickr.com/3767/12858326585_a188d90d82.jp g" target="_blank">http://farm4.staticflickr.com/3767/12858326585_a188d90d82.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/77208531@N02/12858326585/ ]Untitled[/url] by [url= http://www.flickr.com/people/77208531@N02/ ]northdownsouth2012[/url], on Flickr
Posted : 01/03/2014 5:05 pm
 IA
They're M970s - google will sort you out the instructions I'm sure. They're different to other hollow tech cranks so you really should read them before you break or strip something.
There's a dedicated tool for the tension collar behind the left arm. You can get away with out that.
There's a dedicated puller tool that threads in the arm, you then use the bolt like a self extractor. You need this tool.
http://www.chainreactioncycles.com/shimano-xtr-left-hand-crank-removal-tool-m970/rp-prod25630
Is it, but you can probably pick one up cheaper somewhere or borrow one. It'd be nearly impossible to bodge it and you run the risk of damage.
I do of course eagerly await someone's tales of how you don't need the tool and they just pulled the arm off with their teeth...
Posted : 01/03/2014 5:16 pm
Yep, those are M970. You need the tool which reverse-threads into the end of the crank. Keep the crank bolt in place, screw in the tool, then undo the crank bolt - everything comes off together.
Posted : 01/03/2014 5:17 pm
 IA
Wait, how did you get the bolt out? There should be a collar thingy threaded in around it (you use the prongs on that extractor to remove it before you flip it over and thread it in).
I just took he bolt out with an 8mm Allen key- thought I might need the tool- will hunt one down.
Is he missing collar important?
Posted : 01/03/2014 5:30 pm
Not really - I think it just keeps the threads clean. I lost mine around 2 years ago and no real issues - I've taken the cranks on & off at least 7-8 times. Just make sure the threads are clean before you thread the tool in - they're pretty fine alloy threads so the potential for damaging them is significant.
Posted : 01/03/2014 5:33 pm
