https://singletrackmag.com/forum/topic/help-me-repair-my-xtr-pedal-please/
Same problem as above...which didn't really get a resolution.
I'll see about using/getting a bearing puller - I have one but not sure if it's small enough.
In the meantime has anyone had success since the previous thread with any other method?
(Spares/repair XTR 9020 pedals from ebay if you're interested. No idea what the previous owner/s had done to them but both axles emerged unscathed* with some bearings rattling around but leaving the bearing sleeve (and plastic tube) behind.)
TIA!
*edit. well, not quite, one of the cones has broken too, probably due to the relative lack of bearings in that pedal, but we'll get to that if/when the sleeves come out.
*edit2. The bearing pullers I have are too big.
£12.50 ebay bearing puller has done the trick.
Now to stealthily post a wanted ad for the bearing cone.
