XT shortened brake ...
[Closed] XT shortened brake levers
8 Users
Ok this may be the most stupid question ever but I want my brake lever on my XT's to be operated by only my index finger but currently the standard levers are too long so i use index and middle. So can you buy after market levers that are shorter which I know you can on Hope's or is it a case of having to put up with it. thanks
Posted : 23/07/2011 8:29 pm
There were some out there (Dangerboy??) but they only fited up to M765 levers.
Posted : 23/07/2011 8:34 pm
Can you not just move the lever clamps inboard a bit? Depends on how you've got your bars set up, but my XTs work nicely with single fingers when they're inside the shifters.
Posted : 23/07/2011 8:41 pm
Can't you just move your levers further in on the bars?
EDIT Beaten to it!
Posted : 23/07/2011 8:44 pm
Ye that makes perfect sense - wasnt sure I could do that for some reason. did say it was a silly question though 😕
cheers fellas il give that a go in the morning
Posted : 23/07/2011 9:36 pm
What they said. I run my brakes inboard of my shifters for that very reason.
Posted : 23/07/2011 9:39 pm
Ok so the brakes are inbound now and works a treat but the shifter are to close to my hand - Do most people end up removing the gear window so you can push them away from the grips.
Posted : 24/07/2011 11:39 am
Yes, I remove the windows to allow them to be in a comfortable position. Also, I never seem to use the windows, they're just something else to break in a spill.
Posted : 24/07/2011 5:19 pm
yeah windows suck. I often muse that this is the reason why sram got so popular with the dh crowd..
Posted : 24/07/2011 5:27 pm
@toys19: you'd be half right too, other half is the cable pull stroke is much longer (than Shimano) so every things more easy to fine tune & stay put. I wish I had SRAM...
Posted : 24/07/2011 5:32 pm
ahh interesting didnt know that. I went a bit mental and put x0 shifters and deraillers on two of my bikes, the shifting is bloody good.
Posted : 24/07/2011 5:37 pm
