2012 XT Shifter Pod...
[Closed] 2012 XT Shifter Pods - Removing gear change window?
7 Users
I've got a new bike and its got 2012 XT shifters. I want to remove the gear change windows, which I did last night, but I can not see any plastic covers to put back over the space thats left (like there was on 2011 XT's)
Am I missing some thing, or can you not do it on 2012 stuff?
Thanks
Posted : 06/07/2012 7:16 am
You'll need to buy new covers, no longer a freebie tucked away at the back.
Posted : 06/07/2012 7:25 am
Ah great, I did already try googling it but nothing came up, what do I need to google?
Posted : 06/07/2012 7:28 am
Nowt that a small square of electrical tape won't cover up, as I've just done with mine.
Posted : 06/07/2012 7:44 am
Electrical tape wont stay in place though.
Ironically its all sealed apart from 1 very small rectangular section, but if mud gets in to it, thats one screwed leaver IMO.
Silicone sealent might be an option I guess...
Posted : 06/07/2012 7:57 am
Yes it will. Just apply it to the top and not all the way around the unit as that prevents the movement. It works if applied correctly
Posted : 06/07/2012 8:14 am
Had another look last night and its not just one part of the shifter that needs covering. Theres a flat section that would be easy to cover, but there is a second hole at the forward edge of the shifter that is not flat at all.
Might email madison and ask where the hell you get the covers.
Posted : 13/07/2012 6:59 am
If it is the new SLM780 10 speed shifters, the covers aren't shown as a spare part on Shimano's website and the old ones won't fit as the mounting bracket is in the way.
Posted : 13/07/2012 7:11 am
duct tape lasts longer than insulation tape
Though mine have been exposed to the elements for a few years now
Posted : 13/07/2012 7:13 am
To be fair not sure which part shifters they are as they have just come on my new 2012 Anthem X1 2 x 10.
Good and bad news,for SL-M780 shifters, LH part no. 6UV 9804 in stock, RH part no. 6UU 9806 out of stock until the 25th, and they cost £14.99 each.Any shop should be able to order you a set, but if you're stuck give me a call at Sunset and i'll put some in the basket. 02920371321.
Coatesy - They are the covers with shift indicators, I want the ones without.
As Neninja says above its actually parts 6UU 9809 and 6UV 9808
£3.99 each just for a bit of plastic 😕 will get the LBS to order for me.
In the mean time I might just bodge with helicopter tape.
Posted : 13/07/2012 7:32 am
Oops, my fault for rushing before going to work, sorry 😳
Posted : 13/07/2012 5:53 pm
Bodge!! thats not a bodge it's the sort of engineering brilliance this country once thrived on!
Posted : 13/07/2012 11:17 pm
