XT M8000 cranks - u...
[Closed] XT M8000 cranks - use as 1x AND 2x?
5 Users
i'm looking at an XT M8000 drivetrain bundle. if i buy the 2x setup with 2x rings and shifters and mechs, could i also buy a 30t 1x ring and swap it for the 2x rings? and remove the front shifter and front mech?
Posted : 02/02/2017 8:30 pm
 jruk
I've got 1x M8000 cranks and it has holes for a granny ring as well. So yes 🙂
Posted : 02/02/2017 9:07 pm
I've recently looked into changing my 2x m8000 chainset into a 1x. As best as I can tell its the same crank for both.
This makes me think that the chainline might be sub-optimal unless the single ring has spacers to bring it inboard a little.
Posted : 02/02/2017 9:18 pm
 jruk
I put an AB ring on mine which has a corrected chainline. Apparently.
Posted : 02/02/2017 9:22 pm
It's the same crank for 2x and 1x. If you're fitting a single ring then get some spacers and longer bolts.
If you're happy with SLX cranks instead, let me know. I've a new set (off a bike/never ridden) I need to sell.
Posted : 02/02/2017 11:58 pm
Ive recently converted my M8000 1x11 cranks to 2x11, the chainring spacing seemed exactly the same as a purchased 2x11. I actually used the m7000 slx rings on it, as these are steel and plastic, rather than the XT's alloy rings, so hopefully will last a bit longer.
one thing i did notice when setting up the derailleurs was that the chain kicked inwards at a certain point of the crank turn as it went around the large chainring - I eventually found the reason to be the small chainring spacer that sits behind the crankarm, to stop the chain dropping behind it, was actually a few mm longer than the gap, and was actually pushing against the chainring, causing it to deflect - a few minutes with the dremel soon sorted it. - Something to be aware of though, might be because the rings were from a non boost slx crank, and the XT was boost?
Posted : 03/02/2017 2:31 pm
