Xt Chainsets.. diff...
[Closed] Xt Chainsets.. difference between 9 and 10 speed? M770
4 Users
I currently have a triple 9 speed chainset fitted to my bike.XT M770
I was considering changing to a 20 speed set up and was just wondering if i could get away with fitting 10 speed rings to a 9 speed chainset?
there is a m770 10 speed chainset that looks the same as mine which is what has got me thinking.
cheers
Steve
Posted : 21/02/2013 11:05 am
Don't see why not iirc the m770 was the 9spd and they changed it to m771 for 10spd but it kept the same chain line so likely just a rebadging on old stock etc.
Posted : 21/02/2013 11:28 am
Steve - yes no problem with doing that m770 9 & 10 speed cranks are exactly the same, just marked as m770 - 10 by the pedal thread I think.
RDL-82 - m771 refers to the 9 speed 48,36,26t variant which is different & you cannot fit the m770 composite middle ring onto them
Posted : 21/02/2013 1:13 pm
The difference between the 9sp and 10sp triple chainsets is that the rings are marginally closer together on the 10sp.
Not sure what you're proposing to do with a 9sp chainset though? Shimano and SRAM both only made dedicated 2x10 chainsets for MTB AFAIK.
Posted : 21/02/2013 1:18 pm
I was thinking of buying some 10 speed front rings and a bash guard as a start to going 2x10. Was wondering if 10 speed rings will fit onto my 9 speed chainset or perhaps I could get away with using 9 speed chainrings with a 10 speed chain and cassette?
Posted : 21/02/2013 2:32 pm
My bad. I've definitely seen 771's referred to as 10spd though but most shops seem to struggle to get the facts right half the time!
Posted : 21/02/2013 3:14 pm
