Hey folks. As the title vaguely alludes to, I set about bleeding my rear xt. One piston won't retract and the banjo bolt is filled with white gritty bits.
I used to use some elixirs and swapped out to the XTs after loadsa problems. When new they had some jagwire hose installed and bled up. No problems until they went a bit spongy.
When trying to bleed them up first the pistons wouldn't retract then the fluid oozed out of the piston seals. I stripped the banjo off and the threaded end was covered in white gritty bits which I hope isn't, but assume is broken piston.
Does anyone have any thoughts on remedies or am I best to get a new caliper (or some elixors).
Thanks in advance.
either bits of piston (assuming they are white ceramic)
bits of oxidised aluminium
or something used to act as a thread sealant?
That's likely bits of piston. New caliper required.
That's what I thought Shortcut. Pretty crap really. They're not that old and still on their original pads. How do pistons just crumble inside? Grrrr!
