XT brake pad bolts
[Closed] XT brake pad bolts
7 Users
quite fancy swapping the split pin on my SLX disk brakes for some of the bolts that come on the XT (I understand they just fit straight in)
Anyone found a source for these?
Google hasnt picked anything up
Ta
M
Posted : 06/08/2012 12:22 pm
www.ultimatepursuits.com
Posted : 06/08/2012 12:23 pm
cynic-al - Member
http://www.ultimatepursuits.com
Eh?
Posted : 06/08/2012 12:24 pm
soz: .co.uk
Posted : 06/08/2012 12:26 pm
Tech docs say the part number for the "pad axle" is Y8JZ05000, or Y8JZ98010 including the snap ring (threadlock is better).
Perhaps try your LBS to see if they could order it in?
Posted : 06/08/2012 12:27 pm
cheers all,
M785 equiv =
Y8JZ98010 Pad Axle & Snap Ring
Y8JZ05000 Pad Axle
Y8J716000 Snap Ring
Posted : 06/08/2012 12:32 pm
Wiggle has them listed [url= http://www.wiggle.co.uk/shimano-br-m785-pad-axle-snap-ring/ ]here[/url] but showing out of stock until mid-September! If they can't get them, I guessing Madison won't have them, so you'll need to find someone already with stock, or try some of the European shops that have a different distributor...
Posted : 06/08/2012 12:34 pm
I made my own by getting some slightly longer bolts, sticking them in a pillar drill by the excess threaded end and "latheing" them down with a file. Then cut excess thread off.
Took about 10 minutes each.
Posted : 06/08/2012 3:19 pm
what is wrong with the split pin? no tools required and they just work....
in fact i've replaced the bolt on the GFs avids with split pins....
Posted : 06/08/2012 3:26 pm
nothing wrong with the split pins really - might stick with them
Posted : 07/08/2012 11:43 am
