I have the double (10 spd) im wanting to take off the BB, its a press fit BB. I have never removed a Truative type of crankset before. Due to the expense in these things i dont want to go hashing and bashing in.
I have removed the 2 lock rings in non drive side, now then, will the non drive crank remove with the aid of a soft face hammer? it seems pretty snug.
any sound advice removing these?
cheers
scott
just found a little snippet that they are self extraxting. looks like i should of left the rings intact and just would out the 8mm.
is this correct?
Didnt need to remove them,the 1st one you removed is the self extractor retainer,the 2nd is the crank arm bolt.
Put the crank bolt back in.Then refit the retainer ring.
You should be able to undo the crank bolt and it will push the arm off as you undo it..
Please check as you undo the crank arm bolt that the retainer isnt undoing aswell.It should stay still.
