XM421 or what rim?
XM421 or what rim?
7 Users
1 Reactions
Anything else worth considering for a medium weight, mid width light trail/xc wheelset. Looking at about 1750g in 28 hole, 29" flavour on 350 hubs and comp race spokes. Don't think I need the width of an XM481 for intended tyres.
Posted : 22/02/2023 7:13 pm
Happy with mine and CRC appear to be doing 28h at a decent price, have you seen cheaper elsewhere?
https://www.chainreactioncycles.com/dt-swiss-xm-421-25mm-mountain-bike-rim/rp-prod168814
I’ve just bought a couple of XM-481 as spares since the price was good
https://www.chainreactioncycles.com/dt-swiss-xm-481-30mm-mountain-bike-rim/rp-prod168815
Posted : 22/02/2023 7:27 pm
I've found a single rim cheaper @ £50 but am not holding my breath that it'll be fulfilled at that price, otherwise CRC looks the best so far. It looks like I can get away with one spoke length which makes things easier, the same length as needed for a xm481 (future build for different bike). Makes the box of 100 viable.
Also temp tempted to get a couple of the 481s and sit on them.
Posted : 22/02/2023 7:51 pm
Arch mk3? Or is there a mk4 now.
Posted : 22/02/2023 8:00 pm
XM421 and XM481 are both decent. I’ve got both in multiple wheel sets. I’d say I’m slightly knocking the rear out of true recently (no dents) but it’s on a heavy alloy transition sentinel with cascade link / coil / Lyriks etc and it’s getting quite a hard time.
In 650b size they’ve always run perfectly - I’d say the last year or so I’m riding stuff harder / faster and more tech and steep terrain. If I break my 29er one I’ll get an EX511 / EX471 I expect.
Posted : 22/02/2023 8:05 pm
There is an Arch Mk4, it's between the two DT rims for weight and width. A bit pricier though as not discounted much.
This bike doesn't see the big terrain, got the full suspension for that.
Posted : 22/02/2023 8:22 pm
I'd build them up first. Or maybe just buy a chair.
Posted : 23/02/2023 9:10 am
joebristol reacted
 a11y
XM421s are great, mine replaced Arch mk3s which were cracking around the spoke holes. I'm, ahem, 95kg-and-a-bit geared up. 25mm inner width ideal for 2.3 Maxxis. I used ex511/471 conbo on my bigger bike with 2.5s though.
I ordered another pair of XM421s last week, £105 delivered to the UK: https://r2-bike.com/DT-SWISS-Rim-29-XM-421-32-Holes
Posted : 23/02/2023 9:20 am
That's a good price. If my other one doesn't get fulfilled then I know where to go 👍.
I'm just over 80kg kitted up so should be fine on that front. Have 2.3 Barzos to fit on them, again think these will be fine.
For a bigger bike I'd definitely want the 30mm internal. That's what I currently have though it's a 27.5 bike (halo vapour 35).
Posted : 23/02/2023 10:41 am
I was looking for similar last year for an XC wheelset and ended up with the Arch Mk4 as it seemed the best balance of width/weight if you're happy running 'smaller' tyres.
Posted : 23/02/2023 10:48 am
