should i get an X-fusion manic un-used, but 2nd hand off some geezer,
or a Brand X new from Wiggle?
Depends on cost but brand x good and 2 year warranty....
My xfusion has been fine - once you can undo the collar to lube / clean it. It did go back under warranty once when it would stick down - somehow the upper post had bent and was binding on the lower post. The other thing is the bolt for the clamp is quiet small so it's easy to round if you're a ham fisted mechanic.
If you need a 30.9 X 170mm I've got a new unused still boxed brand X for 95 posted.
thanks cp. don't think i can fit 170 but will check.
bramd x feels like better bet, jusy for warranty and safe transaction
