Had Fox 32s and Rebas, both had a really stiff setting but still bounce when out of the saddle. Are there any that lock out completely?
Dunno about forks but I have a DT Swiss XRC shock that does that. Might be worth investigating their forks.
My epixons don't completely lock, but the amount of give in them is tiny when locked out, I can only move them a mm or two with my body weight when the bikes stationary. Guess it's a bit of a safety net if you inadvertently hit something hard.
There's certainly no 'bounce' I'm aware of when riding locked out.
My Xfusions lock completely.
X-Fusion Sweep RL2
My Rebas don’t bounce at all when locked out unless they take a hit from the ground. You can set them up how stiff you want them to lock out.
My RS1's lock completely due to the adjustable flood gate.
I believe the DT Swiss XC forks my mate has do the same, this time via a cable lock out
I had my Rebas on the stiffest setting. It didn't bouce as such when out of the saddle, but they did move a couple of cm.
If DT are still based on Pace then they probably do lock out, cos the Pace ones did.
SIDs
