Hi guys - notice these are cheap just now. My question is can you squeeze in a 148mm boost hub? The add says you can’t but then the review are mixed.
Bump
One last try...
dunno, but ... [url= http://www.hotlines-uk.com/x-tools-pro-mechanic-wheel-truing-stand ]http://www.hotlines-uk.com/x-tools-pro-mechanic-wheel-truing-stand[/url]
Minoura looks like it should.
I've built Boost wheels with the Minoura.
Not tried it, but the jaws on mine open up to 152mm*. By this point they are a little way past upright (130mm is parallel) so you may need an additional way of keeping the axle securely in the jaws possibly.
*I only have had one of these stands so I do not know how generally consistent this measurement is across the product though.
Cheers guys. Likely worth a punt. I dare say it can be modified if needs be.
