X-fusion velvet oil...
[Closed] X-fusion velvet oil quantity/ volume help!
2 Users
In a bit of a muddle lads, wondering if anyone can help me out!
Recently thought I could service forks and stripped my X-fusions, they're velvets from 2013. Everything is fine, however i can't find anywhere the oil volume or amount on the lock out system!
Any help would be massively respected,
Ta
Pete
Posted : 08/03/2016 6:45 pm
 RicB
It's about 70ml I think
You need to put enough in to just cover the clip ring on the damper shaft that you can see when looking down from the top. It's about an inch or so from the top iirc
Don't forget to cycle the damper rod when you add the oil, otherwise you'll under fill it
Posted : 08/03/2016 6:57 pm
Thanks so much, that worked an absolute treat!
Life saver!
Posted : 09/03/2016 7:15 am
