Wrong wheels for fr...
[Closed] Wrong wheels for frame
5 Users
Whats the worst thing that can happen using 26" wheels in frame that`s made for 27.5". Can I use now and upgrade later?
Posted : 23/09/2016 7:50 am
You'll smack your pedals on the ground more often. So yes, you can.
Posted : 23/09/2016 7:58 am
Bottom bracket will be low - in and around 12.5m lower, so depending on your frame and cranks, you might find yourseld smacking pedals on rocks, etc. a lot more than you would otherwise.
Aside from that, you're good.
Posted : 23/09/2016 8:10 am
[i]in and around 12.5m lower[/i]
huge if true!
Posted : 23/09/2016 8:13 am
The offset of the fork would be out too. If my engineering brain is working this early then it would have a similar affect to steepening the head angle a bit to the steering but not much else.
Posted : 23/09/2016 8:19 am
