I was out on a ride today and changed gear on a hill. Unfortunately, I was on the 50 ring at the front and went too high on the rear cassette. Result was that the rear mech jockey wheel contacted with the cassette tooth and ripped the rear mech back behind the cassette. End result is shown in the picture. If the frame manufacturer had used a replaceable hanger I would have had a £20 bill, now I need to find £1800 to replace the frame.
Spoke to the shop and they told me it's my own fault for having the chain too short and that you should be able to use any gear combination on the bike.
Really annoyed about this.
[img]
[/img]
Get it repaired, then set the chain up properly next time.
A hanger may not have reduced your bill; I caught a lolly stick in my rear derailleur with took out the hanger, the mech and 6 spokes...
http://www.carboncyclerepairs.co.uk/index.html
How did the rear mech pulling back snap the chain stay? Is that just from the force of the mech pulling back?
Ouch. Expensive lesson to learn 🙁
i don't think the jockey wheel should come into contact with the cassette even with a bizarre gear combination. I hope you get it fixed up ok.
Carbon repairs nicely. No need for a new frame.
Must have been a hell of a clunk.
A jockey wheel wouldnt as the chain would be straight. What tends to happen tho is the rear part of the mech cage then catches on the next sprocket, resulting it mech death and apparently frame death also tho not sure how, perhaps just too much compression running through frame?
There are plenty of people in the country who can fix that chain stay for approx £100. Not quite sure how a tight chain caused a snapped chain stay though!
The mistake I have made is that I used the old method of putting the chain over the largest chainring and the largest sprocket without the mech in place. I suspect that method is no longer appropriate.
Can a frame with so much damage be repaired, the shop say it cannot, but maybe they have a vested interest in flogging me another one.
The mech is a campag chorus with cutouts in the jockey wheel. The jockey wheel has been destroyed and I think it collapsing was how the rear mech ended up getting sucked around the cassette.
If the frame can be repaired that will be a big plus.
Thanks
[quote=flanagaj ]you should be able to use any gear combination on the bike +1f
Always worth checking after everything is fitted too
Looks repairable to me, will be a couple of hundred to have it done properly but better than a new frame! I had a snapped chainstay repaired last year, not pretty as they couldn't match the mottled effect of the original without some serious work to a much bigger area but functionally it's fine, which is the main thing
Bloody hell, bad luck. Did you use big/big plus two links and then check it? You must have legs like Garth if you managed to kill a chainstay with brute (ooo get you) force.
Go to a specialist menders and ignore your LBS.
It works, you just forgot to add 2 links.
I prefer the big/big plus 4 links and then have a look and see if it is actually too big, then only take that extra 2 links off if it is...
Cheers fellas. I can dry my tears now in the knowledge that it can be repaired.
When I rebuild it next time I will double check that large sprocket + large chain ring does not equal jockey wheel or mech getting jambed up in the cassette.
Can a frame with so much damage be repaired, [u]the shop say it cannot[/u], but maybe they have a vested interest in flogging me another one.
Maybe time to look for a new shop or give them links to repairers and educate them!
I have seen pictures of bikes that have been broken in two, and they have been repaired.
Your repair should cost no more than £100 not including postage if needed.
Or, buy a repair kit and do it yourself!
Given I have vacuum bagging equipment from repairing my windsurf boards, I probably could do it myself. I think I will pass though as a windsurf board repair is not quite as important as a road bike structural repair.
[url= http://www.carbonframerepair.com/index.php/repair-gallery/ ]Here are some examples of bikes a lot worse than yours.[/url]
I buy stuff from [url= http://www.carbonology.com/ ]here amongst other places.[/url]
Steel is real, you might have a dent but not a fubbarred frame made from chocolate
Bad luck chap.
Should fix up fine.
I'm in awe of your use of a 50t ring off road. 😕
Steel is real
Didn't take long. Boring chat.
Steel is real
I once snapped a steel framed Dawes tourer. Not through crashing it either...
They've got a point. Not really what you needed to hear at the time though 🙁
Saw a rear mech die in a similar manner on a full-suss bike where the chain was just long enough when put on the bike, but not long enough when the suspension was fully compressed.
Oooft that's nasty, feel your pain!
What frame was it? Curiosity really.
as matt holme says how did the rear mech going back break the chainstay and so cleanly too?
what manufacturer is it and how old is it? a mate picked up a broken scott (similar place) and had it fixed and it's probably better than new now!
maybe it wasn't the chain but the amount of power you're putting down!
That looks like some serious damage there. Was there some impact there? or is it just result of a huge pedaling moment and a sudden stop?
If you are looking to get it repaired, just be aware that there could also be damage in other places that you may not be able to see. Have a good look at the rear lugs and also all the rear stays. Just to be of the safe side.
What bike is it out of interest ?
It's carbon, and a road bike, no sympathy from me 😉
In all seriousness, I'd be devastated if I'd done that, could have been a lot worse though!
Well spotted. It is my Argon 18 Gallium Pro road bike. Was flying along about 25mph in Poole and then came to a sharp climb so sprinted the hill and then shifted up a couple on the rear. Back wheel suddenly locks up and I skid to a halt on the hill. Rear mech is wrapped around the cassette and partially jambed in the back wheel.
Thought to myself, what the heck that looks wrong, and then spotted the chainstay snapped cleanly across.
It must have exerted serious laterally twist on the rear triangle for the chainstay to fail. That is my only concern that the shear twist involved to have snapped it may have weakened the fibres elsewhere on the rear.
ps - I am a mountain biker mainly. Just like the road once in a while
thats your problem
ive got a repaired supersix high mod - bars stuffed a whole in the toptube - carbon reapirs used, frame looks fine now, ive not refinished it either
Seems pretty much every steel road frame eventually cracks the BB shell, got one in the garage that's been brazed up, carbon repairable at comparable cost to getting new steel tubes fitted.
One of the LVRC guys has a Pinarello that's been repaired three times now by that ^ company, it's still being raced.
Is it not poor form anymore to run big-big? We have a big lad that keeps using that combo and I thought that's why he goes through so many BB30s, hangers and mechs?
The only advantages that steel had over carbon was its better impact resistance and its repairability. It looks like the repairability is becoming less of an issue. Given the use of high end, heat treated, difficult to work steels, the gap narrows even more.
I've broken steel frames and aluminium frames beyond economic repair, but the idea that 'fragile' (actually not), 'plastic' (actually not), frames can be repaired is great.
So maybe the stay snapped first, I snapped a steel chainstay once and when putting power in the rear mech went into the rear wheel as the whole lot twisted.
That is a very interesting theory. The rear mech was wedged in the rear wheel as that too is buckled.
I do find it strange that I could bust one chainstay so badly. If the whole back end had twisted so hard then I would have also expected to have damaged the stay on the other side, but that is fine.
Trouble is, who will believe that theory.
The top tube on my two month old steel hardtail would be to differ, wobbled over between two sheffield stands whilst locking up and put a dent in it 🙁
Round someones house and he showed me his new race bike for this year, the top tube was soft enough to flex under your thumb like a tyre! I bet it would have shrugged off the bike stand!
Didn't know carbon was so 'fixable'.
Maybe one day I'll treat myself to one or maybe Ti.
I have been thinking about this a bit more now and I am struggling to understand how the rear wheel locking as a result of the rear mech getting caught in the rear wheel / on the cassette would cause such failure in the chain stay.
Surely the wheel should have just locked up and that's it?
Shop are not interested so am going to speak with manufacturer next week about this or even another bike shop to see what they say
Is it possible it was the other way round? Frame snapped, forcing the mech in to the rear wheel? Id go with that anyway and go for a warranty replacement on that basis.
Good question, but LBS are saying nope it's your fault. I will speak with Tri UK again tomorrow about this as I am not happy as I don't think such a situation should have resulted in a snapped chainstay.
"Hi,I am very unhappy.I set my bike up with too short a chain and it broke because of it.I think my frame should not break when I do something stupid to it,can I have a new one please?"
What could go wrong?
"Hi,I am very unhappy.I set my bike up with too short a chain and it broke because of it.I think my frame should not break when I do something stupid to it,can I have a new one please?" - See below
If someone can explain why having too short a chain would cause a chainstay to snap then I will gladly take the medicine, but otherwise I will question the reason for the failure.
Any structural engineers out there who could give a layman's explanation as to why this caused such a failure then please do post.
Thanks
Rear mech whipped up nto the stay by your cranking it
Creates a sharp point impact into the chainstay
I have seen exactly this happen on an mtb in the past
* edit - was much closer to the rear axel than that though
Nope, I pushed the rear mech up under the frame to test this theory and like you say the impact point would have been much further back if that was the cause.
Also , do any of these carbon repair companies offer any kind of warrenty or guarantee the rest of the frame is ok.
If not i would not recomend a customer to pursue this option either.
I can't see the big ring resulting in excess chainstay load. Thinking about the leverage, for the same pedal force, the chain force with a 50T ring is only half what it is with a 25T. Big-big is better than small-small for chain (and hence chainstay) load. Quite frightening actually - not a road biker so don't know what size small chainring is, but if it's 110 diameter (55mm radius) and you have 175 cranks, and put your full body weight on the pedal, the chain tension is over 3 times your weight.
But, Big-big does put the chain quite diagonal, and so puts a sideways load on the mech. If the chain is a bit short, so the mech is lying almost horizontally forwards, the chainring to mech distance gets even shorter and the diagonal angle is greater - with the chain pulling sideways from the big ring, it wouldn't surprise me if the mech bent or the jockey wheel gave way. Not quite sure what breaks next but something will.
Sounds to me that the lower limit screw on the derailleur wasn't adjusted properly, and either the chain came off the back of the cassette, or more likely the derailleur cage caught a spoke under heavy torque.
I agree that it's more likely the chainstay break happened before the mech break. As trail rat says - and as proven by the OP in his case - I've also had a mech hit a chainstay but only about 5" or so (mech length really) along, not in the middle, and it only chipped the paint. Saying that though, there could have been a weak point and the mech did cause the break. Dunno. Definitely worth speaking to them again though.
Those frame repair jobs are impressive TBH, I'd be happy to use one of them.
I don't understand the mechanism, but I was on a ride a couple of months ago where the same thing happened when the rider went for big big by accident.
If you think it was rider power that did it then the OP needs to call British Cycling pronto.
Shame none of these pros can output frame snapping torque eh.
Chains are strong, quite possible that as it was shifted to a bigger sprocket it became fully taught, then as mech went round the cassette even more tension was placed on it. Something had to give, in this case it was the stay. How good is carbon in compression...?
looks a weird one.
1st thing i would look at
does the rear mech open to that breaking point at full extension?
if not then how did that break? is the carbon shaped at that break ie slightly curved if so its possible that once the rear mech fully extended and the chain locked up you with your turning/crank motion put enough force into the chain that it twisted the frame and cracked the chain.... highly unlikely as carbon is seriously strong just dont see it fracturing if it hasn't taken a direct point of impact
2nd
argue with the manufacture that the chain stay snapped causing all your problems AND costing you a new rear mech and wheel! due to the failure!
perhaps your cadence sensor and zipties gave sufficient strength to hold that side together ?
How olds the frame ?
I had a hanger snap after the rear much went into the wheel (my fault, limit screws, big-big).
Not sure if this is relevant but the chain stay took a big hit in roughly the same position as your failure. Fortunately not enough for structural damage but has left a nice battle scar.
A few years ago I had a DeRosa Avant Carbon with ultra thin rear stays, bike was fine for <7mths then the stays broke whilst I was up near Alton on a long ride. I had to get the train home. Upshot is I was about to throw the bike through the LBS window in disgust but they replaced the frame and I got to keep the old one. Mate had the old frame and got the stays repaired, bikes still rolling along nicely. I got shot of the replacement and bought an Orca.
I was surprised just how effective Carbon repairs are.
definitely in the wrong place for the RD to hit so does look like in the process of shifting the chain got too right and the frame failed in compression.
the non-drive side would be okay as the drive side is the one under compression and the wheel would pivot at the axle/drop out on the non-drive side.
your RD would then pivot inwards and hit the wheel spokes.
ultimately if the chain was too short (and you fitted it) then it would be user error.
Chainstays are generally built very stiff so a carbon repair should be quite effective and not change the bikes characteristics much.
I had a spill last year that bent mech hanger. Didn't even notice until the next day I went for bottom gear and the mech hit the spokes. This brought me to a VERY abrupt stop, annihilating the mech in the process. Not the same situation as yours, but you have to consider the forces going through the chainstay when the transmission locks up are far greater than just the driving force produced by your legs. Added in to the mix is the force required to reduce your speed (and hence momentum) to zero in less than one revolution. This probably far exceeds any 'designed for' stress. Most chainstays curve out towards the wheel hub, meaning that this force will produce a bending moment, not just a compression load.
I would say the main question is how the transmission locked in the first place.
My tuppence worth...
2nd
Which would be fraud, of course...
Is this like a Scott and has no replaceable hanger?
OP says:
"I have been thinking about this a bit more now and I am struggling to understand how the rear wheel locking as a result of the rear mech getting caught in the rear wheel / on the cassette would cause such failure in the chain stay."
when you lock wheel under braking: firstly you have generally unloaded it by transferring weight onto the front, hence force required to overcome friction is reduced; secondly and more relevantly, the reaction forces in the frame are distributed differently. on a rim braked bike, the force is applied at the edge of the wheel, has a greater torque arm and less force is required to balance the torque produced at the contact patch. with a disc brake, the force counteracting this torque must be higher as it is applied through a smaller torque arm (the radius of the disc) but it is spread through the chainstay (as a bending moment) and the seatstay (as a compression force). also these parts are generally somewhat reinforced or at least braced on a disc braked bike.
when the transmission locks up,the force is produced by tension in the lower chain run, not the upper portion. a straight chainstay would see this force as more of a compression force but a curved stay will see a greater bending moment. the seatstay is unable to provide much support here as it too is mostly under bending, with any additional component force being in tension not compression.
guess that makes fourpence now
The frame was bought new last April. So still in warranty.
I am calling the shop again as I am struggling to understand their reluctance to discuss this or send the frame back to the manufacturer for inspection.
When the wheel locked up the back tyre skidded so that would have reduced the amount of torque the rear wheel would have applied through the chain.
i think youll find the warrenty details will include the clause "must be built by a qualified person"
"i think youll find the warrenty details will include the clause "must be built by a qualified person"" - I was never aware of that.
That was the first question the Manager asked. So even if it was not your fault and you did have a manufacturing defect then you are buggered unless you paid the shop to build the bike?
I doubt many frame buyers are aware of that little chestnut.
How heavy are you Flanagaj?
The fact still remains that the chainstay snapped because of you running the chain too short. This isn't the manufacturer's fault, as frames aren't designed to be misused.
IMO, you just need to suck it up.
"Warranty applies to original owner only and the bicycle must be fully assembled by an authorized Argon 18 dealer." - You were right. What a load of b!llocks that is.
I can't remember a 'you do realise that walking out of the door with that frame and building it yourself will result in the frame having no warranty' conversation.
Very poor
Well try provin it wasnt cack handed spannering that broke it.
He has identified that there was a fundimental flaw in the build that has put force ( compression) into a frame of a magnitude it wasnt designed to handle
Your now trying to prove that the lack of compression strength is a design flaw- thats like me having it run over in a race and trying to claim.
I weigh 72kg
Its in most frames smallprint but i will tell you its rarely exercised unless a grave error was made thats blatently being tried on.
So not a sumo then. Just guilty of running the chain too short.
Why did you run the chain too short?
Trail rat - show me the proof and I will stop my my bitching, until you can I think you need to have an open mind that it could have been either my fault or a manufacturing defect.
ps - Are you the manager guy at Tri Uk?
He is not the manager at Tri UK, but he is a mechanical engineer (one of the few one here).
yes thats me caught red handed.
just looking at it again ....
rotational moment from your spokes ripping the mech inwards could cause that mode of failure.
you could try your luck with the distributor if your having no joy with the dealer but i wouldnt hold my breath.
the skeptical cats will have on their skeptical caps.
Given the warranty condition I don't think I have a hope in hell of getting some sort of compromise agreement. Even if it was a replacement frame at cost that would be something.
I don't agree with this as there's certain gear combos everyone should stay away from, biggest at the front with biggest sprocket at the back, and smallest at the front with smallest sprocket at the back.
email manufacturer direct. State unwillingness of shop to deal with you regarding this.
State what happened and see what they say? If no go then pay to get it repaired.
They can't totally void warranty just because it wasn't built by a particular person. Trading standards and being fit for purpose and all that.
Rich
Edric 64 - MemberSteel is real, you might have a dent but not a fubbarred frame made from chocolate
Not so I know of a very recent case of a Steel failure, wont say more at the moment but all materials are capable of failing with unfavorable outcomes.
you were going uphill and pedalling hard. this puts most of your weight on the rear. to lock the wheel up (overcoming your pedalling force too, lets not forget) and cause a skid (at least in the dry) requires a tremendous force. try doing it by braking....
carbon frames (and hydroformed aluminium) are very light because they allow the designer to remove material where it is not needed to cope with 'designed for' stresses. that is why many designs are inferior to a traditional steel frame when it comes to coping with forces outside those of typical (or even extreme) riding.
michaelmcc: using those gears is considered poor form as it increases wear/mech rub - not for fear of instant catastrophic failure.
as others have said, if the drivechain locked up because the chain length was too short or the b tension screw adjustment was wrong, then thats just one to chalk up to experience.
You stay away from them because of the poor chain line in these gears, which might accelerate drivetrain wear, but won't do serious damage with a chain of the correct length.
A chain that is too short can break the frame when you try to shift into a bigger gear.
I can see now why the shop are not interested in doing anything. The Argon warranty only applies if the bike is built by an Argon dealer.
They should have also made that clear when I purchased said frame. At least then I could have maybe tried to claim through warranty
Micheal mcc - unless he has a triple then big front big back is on a double is not a no no - even more so if he is on a compact
Thts why front shifters have the trim feature.
They can void the warrenty if it was built wrong - which is why the qualified person clause is there.
