would you trust shi...
[Closed] would you trust shims in seatposts ?
9 Users
I have a kona with a 30mm seat tube and bought a shim to step down to a 27.2mm dropper post and wondered if this is a good idea ? I think I have heard bad things about shims , any experiences ?
cheers
Rich
Posted : 23/07/2012 6:43 pm
My old piece of coke can is still going strong
Posted : 23/07/2012 6:46 pm
thats fair enough just wondered if it would ruin the frame somehow ?
Posted : 23/07/2012 6:48 pm
I use one of the USE shims to step down from 30.9 to 27.2, never had any problems. I bought a new frame, didn't need the expense of a new seatpost too.
neva had any problems with shims. just greese you seat clamp up so you can get it real tight
which part to grease the cam lever ?
Posted : 23/07/2012 6:57 pm
never had any issues with shims used them with several different frwme/post combos including a 27.2 dropper in a 30.9 frame.
best way to ensure no seizing is to use a plastic one too....
Posted : 23/07/2012 7:14 pm
Mate made his in the garage for a recent trip to Morzine, worked well and is still working well.
Posted : 23/07/2012 7:16 pm
Well. No. Not really.
I cracked a Kona Hei Hei (the titanium one) due to a USE shim that was too short. I'd only use one as a last resort and it would have to extend well past the top/seat tube junction for sure.
Posted : 23/07/2012 7:19 pm
They're not a problem if they fit properly.
Giant I know for one used to fit them to loads on their bikes as standard from 30.8 & 9 down to 27.2.
Posted : 23/07/2012 7:26 pm
What Goldenwonder said. I used them for years with no problems.
Posted : 23/07/2012 8:38 pm
the round bit at the end of the qr closest to the bike should be a little bress knuckle
Posted : 23/07/2012 8:43 pm
how can you install a shim the wrong way ? I bought a use plastic one with the slot facing the slot of the frame ?
Posted : 23/07/2012 8:56 pm
