Bike Forum
1
Posts
2
Users
0
Reactions
88
Views
Hi Chaps,
The BB Dw Link pivot shaft on my 5-spot is worn, which is causing play in the pivot.
I've emailed Greg at Turner, and Silverfish, but in lieu of a reply...
Will the increased load on the other pivots cause premature wear? And will I need to replace the other bushings if I carry on riding with it worn?
The play is equivalent to what you'd expect when a bearing is worn.
Cheers chaps,
Ricks
Posted : 25/05/2013 9:14 am
If there's more play in the system then you can expect more wear from the other pivots. How much will be difficult to say.
Posted : 25/05/2013 9:19 am
