Woodburners cast ir...
[Closed] Woodburners cast iron or steel ?
7 Users
I will be fitting one in the near future and like the AGA wenlock which is cast iron, but have been told cast iron can warp/crack ,whats your views ? many thanks
Posted : 25/04/2012 6:46 pm
That's rubbish.
Posted : 25/04/2012 6:49 pm
+1 for cracking=rubbish - unless it's red hot and you throw a bucket of iced water over it, then it might. Cast iron for me. Easier to make your own with steel though.
Morso squirrel FTW!
Posted : 25/04/2012 6:52 pm
I've seen plenty of cracked cast stoves, most commonly the top plate.
I've seen cracked Stovax, Morso, BD & CO and Jotul.
Usually it's bad fitting and/or overfiring which causes the problems thgh.
Nevertheless, I'd be quite happy to buy a cast stove. I like the Brosely Serrano range of cast ones.
Watch your chimney sweep's face fall as he sees your Wenlock 🙂
Posted : 25/04/2012 7:00 pm
I went to school in Wenlock.
Just thought I'd add that 🙂
BTW we have a steel woodburner and have never had any problems with warping or cracking. Probably one of those cases where steel isn't, er, real, though. Maybe cast is a blast.
Posted : 25/04/2012 7:36 pm
Bedmaker- why will my sweeps face drop when he see,s the wenlock ??
Posted : 25/04/2012 7:54 pm
I'm having a firebelly installed next month. Made of steel, but chosen because I like the look of it and it's fully british made.
Posted : 25/04/2012 8:17 pm
Dunsley here, made in Yorkshire: the chap who installed it spoke of cheap imports distorting.
Posted : 25/04/2012 8:22 pm
because removing the baffle to sweep through the stove is a PITA.
Posted : 25/04/2012 8:33 pm
