Is it a thing? If not 2fo wearers what do you revert to in the wet? Sealskins and same shoes?
Same shoes (Roosts or DHs) and some warmer socks usually. Sealskins very rarely
Wool socks or sealskins, depending on the level of water.
Have a pair with holes drilled in the bottom to let the water out of the toe box.
Sealskinz if wet and wish i could still get the original 2f0s 🙁
While we are here, can someone compare the Roost to the DH and how is the sizing (perhaps compared to 5.10?)
I have some older 2Fo I didn't get on with but the new ones are well reviewed and fed up with Freerider Pros..
Pretty consistent sizing 44/45 in all shoes, 45 in 2fo roosts, 44/45 in five tens
Same here, but 42 iirc. Specialized shoes always seem to be sized properly.
DHs use the same sole but a sturdier upper. Makes the whole shoe a bit stiffer, and the smooth leather upper probably makes them a bit more weather proof. Both are very good shoes though, not much to choose between them
I have 2e width feet. 5:10s are way too narrow for me. I'm a 10 in a 2e width shoe, and a 46 in the Spesh 2f0,if that helps. (Shoe sizing, like bike wheel sizing, lunacy aside 😂😂)
