Winter shoe prep
[Closed] Winter shoe prep
6 Users
This year I have new winter boots and new shimano cleats to fit.
These things will be hammered though all conditions in the alps for probably 4 months.
So, worth adding stainless or Ti bolts to prevent corrosion?
Posted : 29/09/2017 1:07 pm
My cleats are always fine after a full winters commuting with a bit of grease on them. Back the bolts off every couple of weeks then retighten.
Posted : 29/09/2017 1:12 pm
No, just add some antiseize compound when you fit them and don't overtighten like most (self included) do
Put a blob of hot melt glue inside the bolt holes, will stop them getting chewed up.
Posted : 29/09/2017 1:19 pm
Copper grease on the threads, then blob of mastic/hot melt glue in the hex holes should sort you out.
Posted : 29/09/2017 1:32 pm
Hold a lighter to the cleat until it's warm* to touch, then melt candle wax all over the bolts/cleats to seal the bottom of the shoe.
*only needs to be hot enough to get the wax to stick to it, doesn't need to be melting the shoe.
Posted : 29/09/2017 1:35 pm
Ok, hotsnot and antiseize. Cool. Cheers lads
Posted : 29/09/2017 2:43 pm
