Anyone got an e-mail address or phone no for Windwave? Their website only has an address...
In particular I'm looking for how much oil should be in:
44RC3 Ti 2010 (140mm version)
44RC3 Ti 2011 (150mm version)
55RC3 Ti 2013
and also what type of oil I should be using...
Cheers!
http://www.marzocchi.com/template/contenuto.asp?LN=UK&IDFolder=777 😉
Treat them as roughish guide lines though
Good man! Thanks for that.
Anyone got any thoughts on using 10wt oil instead? The air preload is known to do odd things to the setup of this fork so looking for a bit more support without preload if I can. I know Box Cooksley recommended 10wt in 55s but then he is rather good...!
It's 7.5wt, but depends how much you weigh and how fast you are 😉
Think Box is fairly fast 😉
About 12.5-13st here, reasonably quick.
Agreed. Box is pretty nippy!
Thanks for the info!
Heavier oil will slow it down. Oil ain't that expensive to play around with.
