http://www.merlincycles.com/kinesis-maxlight-ix-29er-carbon-fork-tapered-steerer-57540.html
Those are the forks I'm after purely for the 15mm axle. The only difference with them is that they are 470mm axle to crown. I would have a look on the on-one website but cant find the scandal anywhere.
Any help would be much appreciated.
It depends on your headtube, I'm not sure what the Scandal has, if it's a 1-18th external headset like an Inbred then it won't fit because its a tapered steerer on the forks, if it's a 44mm semi integrated or tapered headtube then it will fit with the right headset.
The axle to crown length will be fine..
If you only have one set of bottle bosses on your Scandal it's a V2 so it will fit.
If you have 2 sets then no it won't fit!
