I've been out grinding up and down hills at Cannock today and the bike is currently a 1 x 10.
The rear is an 11-32 and it's pretty tough going up some of the hills even on the easy cog, would I notice a significant difference changing to an 11-36 cassette or should I consider adding the granny ring back on the front?
I'd be surprised if you didn't.
Yes, you'd notice the 10% difference, but you'd notice the 30-40% from a 2nd chainring more!
Yes
Yes
Just about managed on 32 front, 32 back on my solaris -enough to go to 36 when I went 10speed. 36 is better and I don't feel I need any 1-up stuff. Mind you, SS is fine around cannock!
If you don't then you might just have fluctuating levels of energy and enthusiasm.
I think its 12.5% difference .Yes, you'd notice the 10% difference,
Can you tell the difference between a 28t and the 32t?
Good one
If you bother changing gear then yes
Not sure which I enjoy more.
Threads about 1 chain ring and how to get a wider gear range
or threads about rigid bikes and reducing the pain of bumpy trails
Never thought of it like that. I'll swap the cassette and see how it goes.
Used to ride 32:16 and it was the perfect gear for the Chase including the cheek!
Swap the cassette? I think he just meant change gear
