Will DT Swiss RWS f...
[Closed] Will DT Swiss RWS fit hope pro 2 hub?
4 Users
As title I'm hoping to get one of these but I'm not sure if the hub is compatible. Wheels are hope hoops on (I think) pro 2 hubs, somebody said pro 2 evo are required, does anyone know the definitive answer? Ta in advance
Posted : 02/01/2015 6:58 pm
Asuming your after a standard 135x10 and the hubs Re pro11 then yep.
This. http://www.chainreactioncycles.com/hope-pro-2-conversion-kit-rear-10mm-thru/rp-prod18761
Posted : 02/01/2015 7:03 pm
Cheers, looks like a goer then!
Posted : 02/01/2015 7:23 pm
The DT Swiss RWS is available to fit many drop out/hub configurations -- Front 9x100mm, Rear 10x135mm, Rear 12x142mm (Syntace X-12 type) etc etc. Do you know the drop out config? but as long as you have the correct skewer/thru axle for the drop outs then almost certainly there will be a Hope hub conversion kit available.
Posted : 02/01/2015 7:34 pm
Frame is a specialized enduro 2004, not sure what that means re dropouts, fairly standard I would guess?
Posted : 02/01/2015 7:53 pm
10x135 then
Posted : 02/01/2015 7:56 pm
