Will a thule 591 fi...
[Closed] Will a thule 591 fit 3 inch plus tyres
15 Users
I need two new roof racks and the 591 is in the sales with the release of the newer version but will it take a plus bike 3 inch max tyre ta
Posted : 18/08/2019 4:45 pm
My 4 inch tyres are OK, I use fasty straps instead of the plastic ones though
Posted : 18/08/2019 5:42 pm
IIRC, there's a chubby option (straps and bases) available.
Posted : 18/08/2019 5:45 pm
I don't think the standard straps will fit around a tyre of that diameter
Is a good rack though so any other mount as above or voile straps should work great
Posted : 18/08/2019 5:47 pm
Thanks all
Posted : 18/08/2019 8:02 pm
I use a Thule 591 with the standard straps and it fits a Maxxis rekon 2.8 with a 40mm rim. There is a bit of space left but as above you can get longer straps if length is an issue
Posted : 18/08/2019 8:56 pm
598s with the fat tyre trays
Posted : 18/08/2019 9:23 pm
Isn’t the alloy extrusion profile the same for 591 & 598 though, so the fat tyre trays should fit a 591?
Posted : 18/08/2019 10:19 pm
I found the standard straps on a 591 barely coped with 2.8x27.5
I did try cam straps for 4.0x26 and it was OK until the first really windy day on the A1 and after the bike tried to lunch my roof for the third time I gave up and dismantled it in the rain at the roadside so I could fit it around the stuff already inside the car. I couldn't recommend this to anyone after that drive. I know 591's are good for stupid weather and 'higher speeds' with bikes that are inside the design size so it's the home-brew mod that was to blame rather than the carrier. The 4.0's were physically too wide to sit in the trays was the root of the issue I think. I know some do make replacement trays out of drainpipe.
Now the 598 is the same sort of money 591's were a couple of years ago it hardly seems worth it tbh. Officially the 598 fat trays aren't meant to be compatible with the 591 so I'd want to see that working before committing personally.
Posted : 18/08/2019 10:36 pm
They don't fit. Profile of aluminium is different.
598 is better anyway - longer for slacker frames, better clamp and torque knob. More robust.
Posted : 18/08/2019 10:48 pm
I've looked at both bit its 180 vs 125 at the min
Posted : 18/08/2019 10:52 pm
Sorry Winston, but I'm going to have to disagree as i've done it, the fat tyre adapters do fit 591 perfectly, yes they're a tight fit, i used rubber faced mallet first time but they work fine then for up to 4.8" I have in mine.
James
Posted : 18/08/2019 10:53 pm
Last time I looked 591's were well under £100 and 598's were hovering around the £125 mark. £180 is close to RRP i think. Is this just a seasonal thing? Seems much too large a fluctuation to be exchange rate based.
Posted : 18/08/2019 10:58 pm
Just had a quick look.
Roofracks.co have 598's at £89.99 each if you're buying a pair.
Wiggle have them at £82 but are currently sold out - and say list is currently £129.99.
If you're being asked £180 for one I'd look a bit further...
Posted : 18/08/2019 11:02 pm
No sorry that's a pair for both models I had a pair of 598 in my basket at crc with my bc discount at 154 with 4 left but had a race this morning and came back to them sold out 🙁 should have pressed go this morning but I was in a rush
Posted : 18/08/2019 11:13 pm
@fatbikeandcoffee
You used a mallet.
My colleague also did that and after a few journeys the plastic split.
As I said, the profile is different. You can bodge it and risk breakage, possibly at motorway speeds or you can pay a few quid extra and have something properly designed for the job and legal.
Posted : 19/08/2019 8:42 am
@winston +1
598s and the wider trays is the way to go.
Posted : 19/08/2019 9:24 am
I've carried my fattie on three 598, I just slid the trays out the way and lashed each wheel on with a long strap wrapped around about 3 or 4 times.
Was solid and worked well but was a bit of a faff compared to the usual 30 seconds it takes to do the proper straps up.
Posted : 19/08/2019 9:32 am
Just ordered 2 598 cheers
Posted : 19/08/2019 10:14 am
As a total aside, I never cease to be amazed how many people there are driving around with Thule wingbars backwards on their car.
Posted : 19/08/2019 8:37 pm
I carry mine & my lads fatties on 591's but use some 10mm bungee cords to secure them.
Posted : 20/08/2019 7:42 am
 jeff
591 will not fit my XL slack fattie - maybe the 598 would be better if thule have woken up to the slack/long trend
Posted : 20/08/2019 8:44 am
The standard wheel trays on the 598 fit my Chronicle on a 40int rim.
I bought the fat adapters for the Dune though. I was strapping which worked but was a pain.
Posted : 20/08/2019 8:57 am
My neighbor is afflicted by this. Never worked out how to tell him without sounding like a prick.
Posted : 20/08/2019 12:48 pm
Apart from aesthetics it makes no difference anyway.
Posted : 20/08/2019 12:57 pm
