Will a 11 speed cha...
[Closed] Will a 11 speed chain work with a 9 speed chainring
4 Users
I’m upgrading components on a flat bar hybrid running 2x9 Sora with trigger shifters.
I was planning just to upgrade the right shifter, rear mech, cassette and chain to 11sp.
Q: Will the 11sp chain run properly on the 9sp front rings and mech? Would prefer to avoid the cost of upgrading these if possible
Posted : 29/08/2020 4:56 pm
The internal width of a 11 speed chain is the same as 9 speed - 2.29mm - it's the external width that varies.
This could be a problem with a double chainring as the chain could jam between the rings as it's wider so make sure you ease off the pedals as you shift
Posted : 29/08/2020 5:08 pm
No issues. Running 11 speed chain on 9 speed chainrings. 50/34.As they are much cheaper than fancy 11 speed stuff. And tend to last better as they are steel instead of alloy.
Cheers!
I.
Posted : 29/08/2020 5:54 pm
Ta folks. Will give it a go. Can always change the double later if needed - but hopefully not!
Posted : 29/08/2020 5:57 pm
Your front mech may not work the best.
Posted : 29/08/2020 6:07 pm
