Wifi Tech Help for ...
[Closed] Wifi Tech Help for a Numpty Req'd
4 Users
Over the past few months we have had issues at home with wifi connections being lost by various devices in the house. Often, the only way to reconnect is to turn wifi off on one or two devices & then the one you are using sorts itself out.
Its a D Link DSL 2780 from TalkTalk which has recently had a firmware upgrade to (allegedly) solve any connection issues. According to their tech support there is no limit to the number of devices that can be wirelessly connected but I have a feeling, from what I've read on t'interweb, that there may be a bandwith issue.
I really don't get all this modern jargon but can anyone try & explain/diagnose what the issue might be please?
Posted : 11/12/2012 10:13 am
The first thing you should do is change the "channel" it is operating on as it may be getting interference from other nearby routers.
Posted : 11/12/2012 10:14 am
I did change it that, on advice, to "auto-channel".
Posted : 11/12/2012 10:20 am
No - change it to something like 11.
Posted : 11/12/2012 10:22 am
Ok, I'll try that, ta.
Posted : 11/12/2012 10:23 am
 Haze
Use [url= http://www.metageek.net/?utm_campaign=Software&utm_medium=inssider2&utm_source=AboutForm ]this[/url] to check what other channels are in use nearby, set it to something different.
Posted : 11/12/2012 10:26 am
in addition to the above, if you have a smart phone download 'wifi analyser' or something similar - this will tell you what wifi signals are around your property and you can decide which channel to put yours on. As druid suggested 11 is normally free or up around there as most people set them to auto they frequently just hang around 3/4. Also whilst you're there change the wifi name to something amusing, fun for your neighbours.
Posted : 11/12/2012 10:29 am
Thanks chaps.
And jekkyl, "Nobby's" presence is already in use..... 😉
Posted : 11/12/2012 10:32 am
