Anyone know the max tyre width in a 27.5/650b sektor?
Depends on the year. Current will do 2.8
Not sure-how can I find out the year?
From that document, 62mm or 2.4 inches
This ^ although of course you can probably go bigger than its rated to. FYI to find the year from the serial which is not as good as the revision (B1 for example) the first 4 chars aaTb where aa is the week, T means it was made in Taiwan, and b is the year, in your case 31T5 means Week 31, 2015. What they will do next year though I don't know.
Thanks
Reckon I can up the travel to 150 - will their be a spacer to remove?
Need a lube and general check
