Widest 29er tyre??
[Closed] Widest 29er tyre??
9 Users
After a big wide 29er tyre. Widest I have found is a 2.5 Maxxis.
Is there anything else to look at before I look at a 29er plus tyre?
Posted : 29/10/2014 1:12 pm
Ardents are big !
Posted : 29/10/2014 1:13 pm
Chunky Monkey is on the same carcas as the 2.4 ardent, very big tyres!
Posted : 29/10/2014 1:32 pm
Ardent 2.4 on a 45mm dually is large!
Posted : 29/10/2014 1:34 pm
Surly Knard or Maxxis Chronicle are 29 x 3! <- Doh should probably read the post properly...
Posted : 29/10/2014 1:38 pm
Thanks chaps!
Posted : 29/10/2014 1:58 pm
 gil_
...a slightly wider rim will make a huge difference to any tyre, try a 35mm Blunt or 45mm Dually
Obviously without knowing what you're currently using...
Posted : 29/10/2014 3:01 pm
Currently have a Crest but it looks like a wheelset change might well be needed.
Posted : 29/10/2014 3:21 pm
The 2.5 minion is smaller than a 2.4 chunky monkey at least in 26 version
Posted : 29/10/2014 3:25 pm
Schwalbe Magic Mary is a chunkier 2.5 than a Minion 2.5. try a German website for the best prices - circa 37 euro for a super gravity version
Posted : 29/10/2014 3:29 pm
 gil_
yeah, wider rim will make a huge difference 😉
Posted : 29/10/2014 3:31 pm
I top out at 2.3 on a Crest - look up about tubeless tyre profiles support, there's a link for it somewhere. Basically the more of the tyre is not supported by the rim there more likely you are to get a burp.
You don't want burps.
Posted : 29/10/2014 3:36 pm
