Which do you think makes more sense, the S or RS spec?
Advice welcome, getting back into MTB after a long time off. Had great fun in Swinley last weekend on the T130S. Still need to give the Bird Aeris a go maybe next week, but assuming I get a T130 which spec would you get? Can't justify the carbon versions atm. Mostly riding Surrey hills, Swinley etc. Occasional trip to BPW, or places like Brecon, Peaks etc. May just rent something bigger for Morzine trips etc.
S £2,450:
Fork Rockshox Yari RL
Shock Monarch debonair RT
Rear hub own brand
Gears SRAM GX 10-42
Cranks SRAM GX 30T crank
Brakes SRAM Level TL
14.2kg
RS £ 2,950
Fork Fox Float performance 34 3-Pos Damper
Shock Fox Float DPS performance 3 pos adjust evol
Rear hub Hope Pro 4
Gears XTM8000 11-46
Cranks Raceface turbine 32T
Thanks!
