Whyte s-150 "V2" wh...
[Closed] Whyte s-150 "V2" what's changed?
3 Users
Is there anything fundamental changed on the 2020 models?
I'm looking at the s version and I see there's the slx groupset and a 200mm front rotor (which sounds welcome) but the fork from what I can work out is the same as the 2019 pike just described in rockshox "newspeak"
Posted : 28/11/2019 1:07 am
 wors
Shimano groupset and pike ‘select’ fork. Don’t know what the difference is between that and the revelation on my 2019 version
Posted : 28/11/2019 7:30 am
Thanks for the reply wors. I wondered why they'd put V2 against the 2020 bikes on the website but couldn't find anything online to say anything massive had changed.
So do I hang on for a 2020 model or can I upgrade a 2018/19 model to be as good as a V2 2020 for the price difference? Seems like the RRP is now £2.5k but I've seen 2018/19 s-150s (in a large) going for £2k - £2.2k
The guide brakes on the 2018/19 seemed to get thumbs down from most people. The 4 pot brakes on the 2020 seem acceptable enough from this review
https://off.road.cc/content/news/shimano-quietly-launch-new-cheap-4-piston-brakes-deore-br-mt520-brake-2702
but I can't find out much else...
As for the fork I think a 2020 pike select might have a cheaper version of the charger damper that's in the 2018/19's revelation:
https://www.bikeradar.com/news/rockshox-reveals-2020-forks-and-shocks/
And then I can't really work out whether the 2018/19's rear shock:
RockShox Deluxe R, DebonAir, Fast Black Coating, Adjustable Rebound and 2 Position Compression
is the same/better/worse than the 2020's:
RockShox Deluxe Select + RT, DebonAir, Fast Black Coating, Adjustable Rebound, 2 position compression adjustment
I'm not sure how the SLX groupset sizes up against the SRAM GX eagle
It seems like I might even be able to get a 2018/19 s-150 s and upgrade the brakes and sneak a charger 2.1 damper in the fork for the price of a 2020 and come out on top? Or have I totally missed something here?
Cheers for any advice,
Ian
Posted : 29/11/2019 6:58 pm
I was nosying at these last week. From what I can tell the forks and shock will be practically the same. Both forks use IFP charger dampers.
Gears are similar in range.
Main difference looks to be the brakes although I don’t think the sram guide t were that badly thought of.
Deciding factor for me would be price as I don’t think there’s much in them.
Not sure how you will go on for stock though. Especially 2020 bikes. If you’re north wheelbase look to have a large 2020 at 15 percent off but it’s collection only at Stavely.
Posted : 30/11/2019 10:32 am
Above is for 2019 and 2020. Don’t think the brakes and forks are as good on the 2018. The rear tyre looks pretty poor too on the 2018.
Posted : 30/11/2019 10:39 am
Thanks for the tip off about wheelbase. That could be handy to go and actually see one in the flesh as like you said stock seems a bit limited for 2020. Got to roll round LBS car park on a C RS version in a medium but soonest they'd have the S back in was predicted to be Feb.
Posted : 05/12/2019 10:31 pm
