Whyte 909 pinch fla...
[Closed] Whyte 909 pinch flats - new tyre?
3 Users
Rode my Whyte 909 around Coed-y-Brenin last weekend. What a bike! Goes downhill at least as well as the Spesh Camber Evo (with pikes) that it replaced. The only issue I have had with it is 2 pinch flats on the rear tyre in 2 rides (despite pretty high pressure in the rear tyre).
Wondering buying a fatter tyre and running it tubeless, or just sticking with the stock tyre and getting rid of the tubes. Worried that if I keep the tyre I will ruin my rims if I run a low enough pressure to have any grip?
And is it weird and wrong to have a fatter tyre in the rear than at the front? You don't see that very often...
Posted : 15/09/2016 10:04 am
Perhaps you need to review the tyre pressure in the back? My simple test is putting the tyre against a kerb and seeing if I can bottom the rim out onto it. If I can then its too soft.
Posted : 15/09/2016 10:36 am
so you've gone from a FS to a HT .. if you're bashing the rear wheel on stuff lke you could get away with on the FS its no wonder?
is your yearning for a bigger tyre on the back because you're missing the squish?
Posted : 15/09/2016 11:07 am
bigyinn - yeah, according to that test my tyre was not too soft.
canopy - perhaps I am missing the squish a little, but I think I'm more missing the grip from being able to run lower tyre pressures. Perhaps I'm riding like a thug, and need to gain some finesse?
Posted : 15/09/2016 11:13 am
you'd know best 🙂 it crossed my mind as part of the reason i went FS was because on my HT i was putting some scary hits through the back wheel when i'd made dodgy line choices to get myself out of trouble 🙂
Posted : 15/09/2016 11:20 am
Yeah, I actually bought this bike to complement my full suss, but then my FS got nicked, and I really think the Whyte can do pretty much everything my FS could do, just with a sorer arse.
Posted : 15/09/2016 12:42 pm
