Whyte 129s bottom b...
[Closed] Whyte 129s bottom bracket replacement recommendations
4 Users
My 129s is a year old and the bottom bracket feels like the ratchet on my socket set so am going to pop in a new one. The SRAM GXP which came with the bike seems to have a tendency to wear out quickly so I would like to replace with something a bit better.
Has anybody changed theirs? Any recommendations of what to fit?
Also had to change the headset bearings, not great on a bike of this age. Otherwise love he bike.
Thanks for any help.
N
Posted : 19/04/2015 6:23 pm
Is it a Pressfit GXP BB? If so, does it look like the bearings are pressed into plastic liner cups, or direct into frame?
Reason I ask is because I've got same problem as you with a notchy BB bearing in my Devinci. The last bike I had with GXP BB was a carbon frame with 'direct fit' Pressfit bearings, and I ended up having one of the Hope Pressfit jobs fitted, as I didn't want to end up hammering out kna**ered bearings every 3 months! If the Hope Pressfit one will fit your frame, I can recommend them.
Posted : 19/04/2015 7:26 pm
Whyte is just normal threaded gxp. Best option is hope with gxp adaptor.
Posted : 19/04/2015 7:35 pm
Yes it's threaded. Was looking at the Hope.
Posted : 19/04/2015 7:38 pm
Retrobean, you might be in luck, as I have a brand new unused threaded Hope BB with GXP adapters fitted that I need to sell.
I bought it from 18 Bikes for my Devinci assuming it was threaded BB, only to find it was Pressfit when I got home..Duh!! It's looking like I've got to take he frame in for them to fit one of the Hope Pressfits.
If it's of interest, I can do you the Hope BB for a tenner lass than the best online price you can find for a Hope BB and GXP adapters.
Posted : 19/04/2015 7:53 pm
 mboy
Definitely Hope Stainless (ceramic not worth it offroad) with the GXP adapters. Unless you want to spend CK money that is!
Posted : 19/04/2015 7:58 pm
Bowglie
Hi, thanks.
Can you confirm the size and colour you have?
I have found the BB for £57 (Evans) and the adapters for £8.49. So if yours are right size/col how about £60 inc. p&p?
Do you have Paypal?
Cheers.
Posted : 19/04/2015 8:54 pm
Hi retrob, it's a normal threaded Hope BB (stainless bearings) in black. Still in its original plastic box/tube package with spacing rings & instructions. The spacers allow it to fit 68mm or 73mm BB shells. Price is good with me, and my email is in my profile if you want to drop me a line to arrange PayPal.
Posted : 19/04/2015 9:10 pm
