Having a re-read of The Rider, which describes the back-breaking gearing road racers were using in the 1970s. Like a 20T sprocket as your easiest gear for a hilly race.
Given you would select the sprockets individually, was there some technical reason for not being able to use anything bigger? Something like derailleur capacity, or maybe a six-speed drivetrain wouldn't shift right with a wider-spaced cluster?
Tradition is very strong in bike racing, but surely the absolute misery of pushing those gears up hill was obvious to everyone - even at the time?
I believe that at the time, climbing hills was seen (incorrectly) as a test of strength. It's only relatively recently that sports science has shown that higher cadences are more efficient hence the invention of compact groupsets?
Tradition is very strong in bike racing, but surely the absolute misery of pushing those gears up hill was obvious to everyone – even at the time?
I don't think it was! That was what the pros used so that was what was available and everyone knew that to be a pro you needed to be hard and gritty and ideally in black-and-white. In fact there were many who protested at gearing in the first place arguing that it made riders wimps and wusses.
It was just The Way Things Were.
Lance Armstrong said in an interview or podcast once that if he'd turned up at a race using the gearing that riders were on now, he'd have been laughed out of the peloton - and he'd have done the same to anyone else who turned up with gearing like that. In fact I remember one of my early road races (mid 90's, one of the hillier Surrey League ones) using a 12-25 cassette - this in the days when most riders were on 12-21 or maybe 12-23 - and someone calling me a bloody soft (removed by Mod).
There were technical limitations too of course but basically you rode what was available - and what was available was what the pros rode because everyone wanted to emulate the pros. If you needed lower gears because you were touring you used a normal 39/53 double chainset with a 30T ring sort of bolted into the inside.
I remember as a kid being put off by a ride on my cousin's bike which had a tiny cassette. My first bike was a BSA ( Raleigh built ) which had ten gears but with none of them suitable for living in a hilly area. I am convinced the popularity of MTBs/hybrids was initially due to having actual usable gears.
Machismo.
I guess it's the same reason everyone was running around on 18mm tyres.
With an absence of data people go with how things feel. 18mm tyres pumped up to 120psi feel fast because the road vibrations makes it seem like you a ripping along. Once people started measuring stuff it became apparent that smoother didn't just feel comfier but it was in fact faster.
I guess it was the same thing with gearing. Grinding up hills felt like you were super powerful (or maybe not) whereas spinning away felt like you were out for a Sunday potter (or maybe not).
Data over feelings, imo.
Just had a 1982 bike restored and I was surprised that the original groupset offereded a longer cage mech, which we managed to find. Means it's gone from a 5spd 11-22 or something silly to a 6spd 16-30.
So I guess people were just harder than they needed to be 40 years ago. And why replacement knees have the longest NHS waiting times.
Derailleur capacity in those days were very limited, 13-straight blocks for racing was the norm and 14-28 for touring. Campagnolo, Simplex and the like did long-cage derailleurs but when you’re reliant on a friction shifters, it was harder to get a clean shift. Simply put, you just got on with what you got. I remember being accused of ‘cheating’ when I fitted a 39/52 chainset.
... what was available was what the pros rode because everyone wanted to emulate the pros.
I don't think a lot has changed. When I look at what other riders turn up on to the occasional roadie club run I attend or what is being promoted on GCN, they are the kind of bikes that are aimed at serious racers, and very few in my club do that.
It goes both ways as well.
For example Hoy pioneered the modern sprint tactic of running a huge gear. Before that the received wisdom was you ran a small gear for sprints and timed your attack to jump away from your opponent with just enough track left to reach the line before they could counter. Hoy being the machine he is, just put a big gear on and rode away from them much further out. If he was in front they had no chance of matching his speed (even with a draft), if he was behind he could just ride over them as he was just getting started while their cadence topped out.
There's probably an element of adaptation in it. I've been riding my fixie a lot which means I've been slogging up hills in 42-16. When I jump on the MTB with it's 32-51 gear it feels crap. I can spin it at 90rpm, but not feel like I'm going anywhere, shift up a gear and I'm knackered. If it wasn't for the suspension I'd shift up 5 gears and just grind up the hill out of the saddle. If you get used to climbing in 39-20 or whatever they had, it's not unbelievable that they didn't test out a lower gear and find it slower.
Plus tech moves slowly. They went from fixed, to 1x. Which meant the BCD needed to support a big chainring. Which probably meant that without someone re-inventing the whole drivetrain that 39t/130mm was the best you could get for a racer.
Machismo
No, it was Marchisio that made freewheels 🙂
I remember Richard Cunningham saying something along those lines in a podcast.
Gears you could ride up a hill on, brakes that worked, an upright position and tyres that didn't need pumping up every week.
The budget rigid 90's MTB was a massive improvement over the "racer" or "cruiser/shopper" options people had before.
And for a few people, was the gateway drug - "what if I rode down that singletrack path there?"
We also rode 48x16 fixed gears in winter and rode up nearly everything - hills in 42x21 felt easy in comparison
Brilliant book. Only came across it last year at the local library.
THE RIDER describes one 150-kilometre race in just 150 pages. In the course of the narrative, we get to know the forceful, bumbling Lebusque, the aesthete Barthelemy, the young Turk Reilhan and the mysterious 'rider from Cycles Goff'. Krabbe battles with and against each of them in turn, failing on the descents, shining on the climbs, suffering on the (false) flats. The outcome of the race is, in fact, merely the last stanza of an exciting and too-brief paean to stamina, suffering and the redeeming power of humour. This is not a history of road racing, a hagiography of the European greats or even a factual account of his own amateur cycling career. Instead, Krabbe allows us to race with him, inside his skull as it were, during a mythical Tour de Mont Aigoual.
I'm sure I heard about pros having to get off and run on super steep hills in races in the 70s/80s?
When I was a kid (just before MTBs came out) road bikes were referred to only as 'racers' even if they were cheap Apollo crap.
Bikes were typically 10 speed with 5 at the back and 2 up front. Friction shifters on the down tube. Just didn’t have the range and precision of modern shifters to allow more cogs and couldn’t cope with a wide jump between cogs modern mechs and cassettes can have.
Early 90s I had 2x6 52/42 with 11-24 for "general" use. It was possible to go bigger on the block (I fitted up to 28 for hills) but only having 6 speeds would give big jumps between gears. I also (very briefly) experimented with 11-21. I have had that old bike on a modern wheel off turbo fitted with an 11-34 cassette and it shifts fine (if you turn off the indexing). So no real technical limitation back then other than the number of speeds available.
Bear in mind that tourers had 3x chainsets and most of the French cyclists I saw back then were on 3x spinning up the hills. If I remember correctly 3x did also see some use in the pro peloton too before more speeds became available at the back. Now we have 12 speed we are seeing some use of 1x in races.
They also didn't routinely go up the sort of mountains after multiple days in the Alps that the riders in the grand tours do now. Alto d'Angliru was only introduced in 1999, Zoncolan in 2003, and a lot of the passes that are included now weren't even tarmaced.
Oldy timey gears would've had you off and walking, and no one wants to see that.
Raced 53T 12-23 10 speed yesterday and ride fixed 49x16 everywhere. I must be old school. Truth be told; the race was a circuit race and gearing was perfect. The 23 was originally so I would not spin out in a sprint on a compact 50T chainset, but I've gone to old DA7700 now instead. For fixed, rules are a bit different. I do like good grind up a hill on fixed - and you can get up steeper inclines when you have no choice but to heave. Surry is not, however, my native Devon, however climbing Remenham hill out of Henley was murderous a few weeks ago!
Big Mig rode a triple in the Alps - it was referred to as "Tea-time" in The Comic with a photo feature! The BCD of 130 only allows relatively large (38T) inner rings, and it took a long time to get smaller semi-compacts rather than granny gears.
My first proper bike was like that. Dawes Audax. Those stupid suicide brake levers, downtube shifters and 23c tyres (23c cos it was "audax", not the 19c it'd have had if it was a true "racer").
I remember trying to finesse the gear changes, trying to get it just into this cog, not that one, riding one-handed up a hill fumbling around trying to get the gear selected.
Then I got my first proper MTB and that had 28/38/48 chainset coupled with a 12-28 cassette (must have been 7sp back then). A low gear of 1:1! Wow! That was a true wall-climbing gear. Reading MBUK in the months before my purchase it was how they differentiated a "true" MTB - if it had a 1:1 gear ratio, it was the real deal. Also my mate had bought a new MTB a month or so before me but his didn't have a 1:1 ratio so mine was better!
I don't agree. I've built up retro touring bikes with modern drivetrains and they work just fine, the limiting factor of friction shifting is that without indexing it's harder to get it just right on a hyperglide cassette. If someone made a 11-32 cassette with plain teeth I reckon you could get it to shift just fine with friction shifters.
It didn't seem too bad at the time. 30+ years ago I rode 42/52 13-18 everywhere, unless it was the winter fixed bike on 42x18. Peak district? No problem. I was however young, thin and strong, none of which I am now.
Yesterday I was cursing my 34x25 bottom gear as my rather rusty road legs (just) got me home.
more importantly, what on earth did they expect anyone to do with a 48:11?
26x1.8 tyres would have a diameter of ~650mm
29x2.5 is ~750mm
It's only the equivalent of a modern 42:10, i.e. a gravel bike, which is what we'd call a 1.8" (45c in cool gravel money) tire these days.
I’ve built up retro touring bikes with modern drivetrains and they work just fine.
With friction shift? Blimey struggled to index on 5 speed never mind 12 or 13.
Don't forget, this was the days when a "DH race" meant bombing down a massive fireroad in the Rockies on a 60T chainring! John Tomac even famously used drop bars in a few races cos the courses were just flat out high speed charges down a gravel road or sometimes a ski slope! That was DH. You needed big gears.
IIRC, it was just part of a progressive change. It was one step smaller than what had gone before!
I remember when 22/32/42 came in and I thought it was dumb - whoever wants gearing that low?
These days, I'm perfectly happy to freewheel where necessary 😅
For some perspective, my "Gravel" (well titanium cross) bike is currently running Gevenale shifters as friction not index - it's 11 speed shifting on a 10 speed wheel and also 10 speed cassette on the Kickr. Shifting is light and instant. We are conditioned to index shifting now, but forget just how nice it is to smoothly move a lever. And you can't drop nine cogs as fast on anything else 😉 . Shifting is perfect, and trimming barely noticeable.
@crazy-legs “ (or a soft #####),” are you still stuck in that era? Not an acceptable term to use, in my opinion.
@crazy-legs “ (or a soft #####),” are you still stuck in that era of macho gearing? Not an acceptable term to use, in my opinion.
@wheelsonfire1 - you're right. That was the second mention (the first already removed by a mod) where I was called such a term for using low gears and then carried on the simile as a sort of reference to the first part of the story. But with the first part removed, the second makes no sense.
The first got removed (and I got a warning), the second was clearly missed which I hadn't noticed either, I thought the mods had removed both mentions.
I apologise and I've reported my own post to ask the mods to remove the second mention as well. It was ill-judged on my part and I'm sorry.
I don’t agree.
Try getting accurate shifts without the availability of compressionless outer, the linear wound stuff we get now is an absolute godsend compared to what we had before.
Go faster?
Pretty sure the highest stock ratio has never been 48:11 though. 48:13 and then 46:12 i think? You could make a 48:11 if you wanted though.
And some races you needed a ratio like that, 60kph down a couple of km of downhill forest track to get to the next 200m of slop before the 80 other riders got there and got (literally) stuck in. One reason i still have 2x on my XCM bike, there are long sustained bits where you might actually end up in a proper echelon in some of the marathons round here.
Can still remember the abuse i got (in the 90s!!!) when i ditched the 52/42 and 11/23 for a 53/39 and 12/25. (Campag Croce 8 speed with Syncro 2 DT shifters IIRC.)
Gave me almost the same spread of gears at the top, more usable gears in the middle and a lower bottom ratio.
The abuse stops when you start winning stuff though.
They also didn’t routinely go up the sort of mountains after multiple days in the Alps that the riders in the grand tours do now. Alto d’Angliru was only introduced in 1999, Zoncolan in 2003, and a lot of the passes that are included now weren’t even tarmaced.
They went over quite a lot of them before they were tarmacced, to be fair
I suspect people use to ride the stuff the pros rode with absolutely zero consideration for whether it was the most appropriate tool for the job
a bit like they do just now. Yesterday I took my tarmac out on an 80 mile ride. It’s an uncompromising race bike and my back and neck were in bits at the end. Meanwhile I have a lovely giant defy in the garage that would be far better suited for the job.
It was before gears / brakes / geometry became woke obviously.
I ran Paul's Components adapters with Ultegra bar end shifters on my XC Race bike for years, sometimes in friction mode. But usually not, because it wasn't as good. I bought them because the setup was both much cheaper and much lighter than the XTR alternative - you can't say that very often. However now I run RFP. So I haven't forgotten 🙂
The range a mech (or two) are able to work through now is certainly much better than it was. That plays a huge part.
But there is a mindset change too. I remember in 2005 or 2006 changing my chainset for the Fred Whitton to one of those new fangled compacts AND switching to a 12-27 block. Got a lot of "you going soft?" teasing. And then the day after it was back in the shed to take the compact off and put the 53/39 chainset and 12-23 block back on because the compact and big cassette was just for crazy hard days. And I wasn't even racing by then, so not sure what I was thinking.
I think my first proper road bike in 1987 or there abouts was 52/42 up front and a 12-21 7spd block and that was considered pretty easy gearing.
True. The majority of recreational cyclists (meaning those who don't race but including those who like to "make progress") have never needed 52/42 or 53/39 and I'm sure that for a lot of us 50/34 is "overgeared". I am a lot older, slower and weaker than I was back in the 90s and even my 46/34 11-34 Diverge gearing is on the high side for me. There is no way I'm going to be pushing 46x11 ever. That's over 40kph and if I hit that these days it'll be downhill and freewheeling. I'm eyeing up "modern" 1x gravel bike groupsets, something like 40x50 would be nice!
True. The majority of recreational cyclists (meaning those who don’t race but including those who like to “make progress”) have never needed 52/42 or 53/39 and I’m sure that for a lot of us 50/34 is “overgeared”
I don't know, I'm "That's a good FTP if you weren't 95kg" fit. And I can hold ~24mph in a group which is 50:13 @85rpm. I can sustain about 110rpm so there's headroom still, but it's close enough that even slight downhills start top feel fatiguing spining to keep up, and not enough that I'd not consider one of these newfangled 52-36 chainsets especially as there's not really any compromise anymore with 11-32 12s cassettes.
That reminds me, I need to swap gears on the track bike as accreditation gets competitive tomorrow and my current nice spiny gear that's nice to hide in a group in won't cut it anymore.
Isn't this simply just a 'they didn't know any better' with a bit of 'they hadn't quite developed the right technology yet' and a big dollop of cultural inertia thrown in?
Plus look at the mad fuss roadies made over disc brakes when they decided they were the equivalent of turning your wheels into lethal buzz-saws. There's something about riding on the road regularly that turns people's brains into weird, atavistic mush. If they'd had square wheels, they'd have stuck with them for decades because that's the way things have always been.
But mostly, they just didn't know any better.
My first bike as an "adult" back in 2016 or so was a gifted Claud Butler 531 steel thing, with friction shifters and 53/42 and 11-21 I think.
Stunning bike but absolutely brutal to climb anything on. Pretty sure I remember having to get off and have a rest half way up Arthurs Seat. I'm sure most of that was because I was a wannabe powerlifter at that point and hadn't done anything resembling cardio in a few years, but still. Makes me chuckle now thinking about having a 34/34 lowest gear on my road bike.
Derailleur tech definitely got to the point where MTBs were running 28 tooth cassettes well before roadies moved away from 12-21/13-23 cassettes. Roadies are notorious luddites and suffering is a key part of the road-racing mythology. As an expert level MTB XC racer in the early nineties I copped abuse from roadies for turning up to (non race) road events with a 12-28 on a MTB, but I enjoyed the climbs a lot more than they did.
I had a road bike with a 42/52 (39/42 not a good idea as they’re both divisible by 13) 12-21 and it was horrible; years later on a modern road bike with 36/52 & 12-25 life was dreamy and a 12-28 cassette was lovely in the Pyrenees.
Rim brakes were still rubbish and road bike geometry still needs a rethink.
There’s something about riding on the road regularly that turns people’s brains into weird, atavistic mush. If they’d had square wheels, they’d have stuck with them for decades because that’s the way things have always been.
My first cycle club had the standard club contingent of Old Fogies and their outrage if you turned up to a winter club run on a normal bike rather than "the winter bike" (a thing made of lead and iron with a fixed gear ideally of 62") was tangible. That was just The Way Things Were and to go against that trend was considered quite insulting.
That traditional thinking imposed itself in all sorts of areas. MTBing was very much not the done thing. They reluctantly accepted that it was OK for kids to do when playing around - kind of like a big BMX but BMXing was far too radical anyway. Cyclocross and track were acceptably pure. The introduction of STIs was greeted with collective scepticism. All these posh newcomers on their newfangled kit.
It took me a while to realise that it was simple jealousy. They'd grown up riding 531 steel frames (cos that was all there was) using 19c tubulars (same) and 5, maybe 6 sp gearing, friction shift. And suddenly here was this new stuff which was WAY better - carbon and aluminium and decent clincher tyres and more gears and better brakes and they now were too old to appreciate it. So they got really grumpy at the folk who could just go out and buy this stuff rather than (as they saw) earning the "right" to ride decent kit.
That reminds me, I need to swap gears on the track bike as accreditation gets competitive tomorrow and my current nice spiny gear that’s nice to hide in a group in won’t cut it anymore.
What gear are you running? 84" (50x16) is typical for accreditation, but >90 is where the pointy end of racing has been for a while. I run 49x16 on the road - 82" and get asked a lot how it feels - it's about 52x17 in semi-compact speak, so half way down most people's 10-11 speed blocks and is OK for medium paced (21-22mph average) club riding. When it goes downhill, I'm out the back though. Just gone down from 98" to 95" for track racing and fixed wheel TT racing at 25 mph and 90RPM average.
I don’t know, I’m “That’s a good FTP if you weren’t 95kg” fit. And I can hold ~24mph in a group which is 50:13 @85rpm.
Yep that's downhill only speed for me and freewheeling.
We are definitely not in the same category of cyclist.
Its interesting. Roadie wise, every time I've done the new-fangled things that are supposed to be "better", my garmin tells me I'm going slower.
23mm->25mm=>28mm tyres = slower, without any noticeable increase in comfort.
Back in the day when I was a student, I used to run 52/42 and 13-23. My dad told me not to use the 21 or the 23 sprockets unless we were in the Peak or one particular local climb. We rode everything, because why wouldn't you? It wouldn't be fun if it was easy!
When I got my first nice roadbike in my 30s, it had 53/39 and 10s 12-25. I could get up everything in the Peak (my now local riding). I built myself a new bike for my 40th with a compact on the front so 50/34 and 11-25. I didn't really notice the hills get any easier, but I did notice my average had dropped by 1mph...
Unless its super silly steep, my slowest usable cadence is about 70. It doesn't matter what the gear is. If I'm still sat down on a climab and pedalling, I'll be doing at least 70. Give me a bigger gear and I'll just go a bit faster.
I think you just adapt to what you have. If the gears are easier, you put less effort in (unless you're riding to a power meter). If they're harder, you get fitter and stronger because you have to.
(this is all for a semi-fit MAMIL blundering around his local a couple of times a week. If you're a pro racer smashing out 3 weeks solid racing in the mountains - you may have different needs to me!)
I have two lovely 90's road bikes, one Dura Ace and one 600/Ultegra. Over the years I've changed chainrings and cassettes, from a 52/42 and a 12-21 block (sometimes 12-19 for TT's), to a 53/39 and a 13-26. The 39-26 is as low as I can get both of them - makes it hard work up some hills. Given I'm mid 50's the recent purchased was a used CX bike that I can get 34x34 as bottom gear and it will go up walls - makes it a far more pleasant experience.
We didn't really have much choice in the late 80's 90's with gears.
I still love riding the bikes, but if I'm doing distance with lots of hills, or steep ones, out comes the CX on road tyres.
Disc brakes are still fugly though.
I've never got up Jenkins Chapel (Peaks) on my old road bikes - can just about do Mam Tor (which was unpleasantly hard) but the 34x34 just made it relatively easy. My Dura Ace 7402 mech is tiny compared to the newer stuff, but it is beautifully made, far better than new Dura Ace - just oozes quality.
I pushed mine up Jenkin Chapel back in the 90s. Took my road shoes off and got my white socks covered in road tar. Some years later I rolled my car coming down. Happy days eh?
Mixture of what was out there, what was needed and tradition. You could stick a 28t rear on but with a 5 or 6 speed block there were some horrible gaps, nearly as bad as on a modern MTB cassette but at least you had two rings to help.
I reckon that there was a higher proportion of "serious" cyclists out there. The club scene was greater and whilst my experience is somewhat limited, only joining a club in 79, I am sure that we saw far fewer non club riders. Thus on the whole the novice rider was less common and thus easy gears were not so important. We grew up pushing a lower cadence and found it fine. Some of us still do. Club runs had the attitude that you pushed if you needed to or better still worked for your ride.
Nowadays we have better, or should I say greater, access to what others are up to so it easier to jump on a bandwagon. Just look at the silly pedalling cadences that were adopted when Froome first came to notice.
Things changed when MTBing came along. Gearing was pushed as easier and was thus attractive to a certain element. Mega marketing took over.
Finally we don't need to have really low gears. I couldn't do it now but I used to tour on my race wheels as they were nicer than my normal ones. Only a 5 speed straight through block. 13 up with a normal 42/52 on the front. This was before the new fangled 39/53 came in. Tomorrow is the second TT of the year and the way home has a good chunk of 10% plus. The TT bike has an old screw on HED disc wheel. I have gone all wimpy with a 12-18 block but the hill won't be a worry as I have an equally easy 39 inner on the front.
I think that people look at older gears in horror but they are not as bad as they seem. In much the same way as people laugh at those of us who don't use a mobile phone.
The number of cogs on the cassette (or freewheel) is probably the main technical reason for historic gear ranges.
Closely spaced gearing is important for road competition, and on old 5 speed blocks, getting an adequate top gear with a "modern" low gear would have resulted in gear steps that were far too wide. With more than double the cogs on a block today, it's much easier to achieve both properly spaced gears and a nice low end.
I think that the changing market has also driven technical changes. Very few "racing" road bikes are actually used for competition, so instead of race focused gearing, there will be a much bigger demand for compact chainsets and large range cassettes to provide more forgiving ranges, particularly as the people spending serious money on bikes are perhaps more likely to be of mature years...
I used to race hill climbs on a bottom gear of 39 x 21, but for long distance riding these days I find my 48-32 sub compact and 11-28 cassette is a great combination.
Sum of youse is well old, innit.
This is why. FFS.
This is why. FFS.
This is why. FFS.
Apologies, posts went as wonky as new mechs.
And the new stuff get's mangled easier. My XT RD-M737 - slightly newer than above (many pics - sorry) is way stronger than the X9 10 speed mech I have on my newer FS bike.
Blimey I hadn't realised how chunky those XO mechs are.
They didn't like their knees.
It took me a while to realise that it was simple jealousy. They’d grown up riding 531 steel frames (cos that was all there was) using 19c tubulars (same) and 5, maybe 6 sp gearing, friction shift. And suddenly here was this new stuff which was WAY better – carbon and aluminium and decent clincher tyres and more gears and better brakes and they now were too old to appreciate it. So they got really grumpy at the folk who could just go out and buy this stuff rather than (as they saw) earning the “right” to ride decent kit.
You sure you're not talking about ebikes? 😉
they just didn’t know any better
I think this and I think it was also driven by the sports science of the day. Back in the 60's and 70's the accepted way to go faster was to build bigger muscles and run big gears at low cadence. That thinking changed when people started to take sports science seriously.
Now we know that a lighter athlete, with less muscle mass, spinning a faster gear can be lighter and make more power. Hence he/she can be faster. I think this has driven us all to take higher cadence riding on different gear ratios seriously.
I didn’t really notice the hills get any easier, but I did notice my average had dropped by 1mph…
If you use lower gears it may feel easier just because you could well just be going slower. My fastest up hill times on my regularly ridden loops are all on fixed gear but the fastest overall loop times are all on the occasions I had a geared road bike because I am losing out on flat and downhill.
As someone who has ridden fixed gear for over twenty years I don't have a problem with the relatively hard gearing of old but then I don't live in the alps.
They didn’t like their knees.
Rosedale chimney on 42x21.
Most of the Passes in the lakes (and peak district) on the same set up. Sometimes with a large carradice saddlebag too and enough kit for a couple of nights in a hostel.
I did weigh under 50 kilos at the time, so the biggest risk was actually getting blown off the bike...
Rosedale chimney on 42×21.
There used to be a famous road race called Tour of the Peak which included several ascents of Winnats Pass. On the first ascent of it one year, Rob Hayles broke his front mech trying to change down and it left him stuck in the big ring. He had to ride about another 3 ascents of Winnats Pass in the 53. 😳
You could apply this to many aspects of MTB tech over the last couple of decades. Everything from disc brakes, tubeless tyres, suspension and dropper posts apparently was only a skill compensator for a skill they had aquired over many years of riding.
One of my favourite lines from The Rider is “his 21 was as clean as a whistle” – so even if you had “low” gears it was a sign of strength never to use them.
Laurens Ten Dam has a short film were they ride the route (on a modern bike), and speak with Krabbe and other Dutch cycling writers - really good, and they use that quote as the title.
Would have been mid 80's and I did some recreational road but around Sheffield found it a bit tough to turn the cranks over ...I knew a guy I dealt with on a daily basis was a "club rider" so I asked what would help ...surprise surprise MTFU.
The one time I broke my rear mech and SSed my Salsa, I was definitely not quicker. Even before I had to stop and walk. I think people who think you always ride less hard with gears don't know how to pace.
The reason I asked my dad for a mountain bike was I didn't want to ride the bikes they did in the touring club my dad belonged to, as they were the most boring people ever - to the 15 year me anyway. It wound them them that I could carry on pedalling when they got off and pushed, as if lower gears was some sort of personal slight to them.
Im a fairly fit club cyclist. Last year I rode up hardknott, gearing was 34/32. I remember looking down at my powermeter, and was pushing over 5 watts per kilo at about 60rpm. And I thought, ‘how the hell did folk get up here on a 39/23’
I think people who think you always ride less hard with gears don’t know how to pace.
Not really. I ride less hard up hills when I have a geared bike because I have the option to and ultimately I go slower. Not really an overly conscious choice but more to do with just having the one gear so getting on with it and not letting the cadence drop too much.
5 W/kg at 37.5rpm?
thats still a pedal stroke every 0.8 seconds, so very plausible for a high gear gurner.
Tour of the Peak
I may have ridden, errrrrr, started that race on occasion...
If you see old footage of them riding uphill they look like single-speeders who are on a 1 min grunt hill, but they pushed that gear/cadence all the way over the Alps. To do that you must have a different type of fitness and strength to riders now.
I used to work with a guy who'd raced the Archer GP on a 42-21 bottom gear, late 80s-early 90s I think? If anyone knows those hills (Whiteleaf in particular.. always hated that climb) you'll know why I think that's nuts. 10 years older than me and I hardly kept up with him hill walking, never mind on the bike.
As above, just really really low cadence. Ask a singlespeeder.
Exactly, so if you're used to consciously finding and sitting at your limit for a particular climb and selecting the appropriate gear, you can do it. Sometimes I get the pacing wrong and have to drop down, but if I were in bottom gear or singlespeeding I'd have to get off at that point.
It is not about pacing, I go faster on a fixed gear up hill as need to to keep cadence up. Pacing doesn't even cross my mind.
It is not about pacing, I go faster on a fixed gear up hill as need to to keep cadence up. Pacing doesn’t even cross my mind.
Same on my SS road bike - I have to go for it uphill, there's no option to sit and spin.
