Why are my tubeless...
[Closed] Why are my tubeless tyres burping?
4 Users
Following on from the other tubeless burping thread and to avoid hijacking I have been meaning to post my own question.
I just built my new bike and chose mavic 821 rims with hans dampf tubeless ready tyres. I have ridden it about 5 times so far and burped on 4 of the rides and on 2 of the rides burped multiple times.
Every time it has been around a 1 - 2m landing onto off camber ground from a jump or drop. Both front and back have burped.
I wouldn't normally ask this question as an off camber landing isn't ideal and will always be more likely to burp but I have been running tubeless hans dampf front (exactly the same model as new bike) and nobby nic rear now for around 3 years on mavic 819’s and never burped once. Same jumps and conditions and some much worse landings I shouldn't of got away with. Pressure is about the same and I have tried a higher pressure on the new bike but it made no odds.
Everything I read said that the wider 21mm 821 against a 19mm 819 rim would be better for tubeless.
The most annoying part was having to borrow a mates bike to go fetch a pump as I have had no punctures or issues for so long I don’t bother carrying spares or tools when riding locally.
Thanks
Andy
Posted : 29/09/2014 11:17 am
Can't help with the question on the 821 rims, but my 819 rims have also been perfect for 3+ years. Not a single burp with proper UST Maxxis tyres (so a bit of a weight penalty).
Posted : 29/09/2014 11:20 am
Also worth mentioning that I also run tubeless on crossmax st's and stans crests whatever they measure and have never had any problems with these either.
Posted : 29/09/2014 11:37 am
What tyres are you running?
Look up ERD and ETRTO
Posted : 29/09/2014 11:45 am
Just checked the rims ETRTO and the 821 is 559 X 21 and the 819 is 559 X 19.
The hans dampf all have ETRTO: 60-559 (26 x 2,35")
Posted : 29/09/2014 12:05 pm
How old are the HDs? we're they on your old rims before putting on your new rims?
Posted : 29/09/2014 12:08 pm
They are new tyres on new rims.
I put them on with a tube in for a few days to shape before taking the tubes out and putting the sealant in. Both went up easily tubeless with a joe blow.
Posted : 29/09/2014 12:10 pm
 Del
how much pressure?
Posted : 29/09/2014 2:49 pm
I normally run around 30psi on the 819's. I tried that first ride on the 821's but it felt very hard but burped. I increased to 35psi and it still burped.
Even when I have not bothered topping up the tyres on the 819's and they have been as low as 15psi they have never burped.
Posted : 29/09/2014 2:52 pm
