why is garmin edge ...
[Closed] why is garmin edge showing wrong distance in courses menu?
5 Users
load the hayfield-jacobs ladder tcx in bikeroute toaster and bikehike and both showing 34.+km , however when I upload it to the edge unit it is showing different ? 😐
[URL= http://i1073.photobucket.com/albums/w396/wolfenstein782000/8F90B8FC-637B-47E8-A140-1BA8AE928D69_zpsuj5hi40w.jp g" target="_blank">http://i1073.photobucket.com/albums/w396/wolfenstein782000/8F90B8FC-637B-47E8-A140-1BA8AE928D69_zpsuj5hi40w.jp g"/> [/IMG][/URL]
[URL= http://i1073.photobucket.com/albums/w396/wolfenstein782000/BF83C10F-172E-4AB3-B72A-17F79B437EA7_zps58uu1r1h.jp g" target="_blank">http://i1073.photobucket.com/albums/w396/wolfenstein782000/BF83C10F-172E-4AB3-B72A-17F79B437EA7_zps58uu1r1h.jp g"/> [/IMG][/URL]
Posted : 05/04/2015 9:25 am
Have a look at the course on the Edge(try uploading it back to your PC). You'll likely find that it has rerouted according to how you've set it up.
Posted : 05/04/2015 9:27 am
I believe the values show on the Garmin are the distance and direction to the start of the course from your current location.
Posted : 05/04/2015 9:42 am
thanks scotroutes, will have a look at that, I am still learning how to operate this thingy... rerouted you mean that it calculated 2 loops?
I upload the tcx files manually to SD, garmin software doesn't work for some reason and ridewithgps uploading also not working 🙁
Posted : 05/04/2015 9:45 am
@neil is that what those values mean 😮 .. will check ... i look silly now creating this thread 😳
thanks lads appreciate the replies
Posted : 05/04/2015 9:47 am
No you don't.
I also wandered why the distance was so far out from the route length.
Seem obvious now its been pointed out to me.
Thanks Neil.
Posted : 05/04/2015 9:56 am
No worries folks. It had me guessing for a while too.
Posted : 05/04/2015 10:42 am
It lists distances there in the same way as to points of interest etc, ie distance from current location. Also took me a bit of time using it to twig to that one, ignored it at first since the routes themselves were correct.
Posted : 05/04/2015 10:52 am
