Why can't I straigh...
Ā  You don't need to be an 'investor' to invest in Singletrack: 6 days left: 95% of target - Find out more
Why can't I straighten my rotor
5 Users
1 Reactions
SRAM CL on a road bike. I can't set the caliper up right because the rotor isn't true (maybe as a result of a big crash a couple of months ago) and so it runs on part of the rotation.
I've had this many times before and with an adjustable spanner and a bit of patience have managed to true it back. And indeed I can do the same here too, and get it free running where it takes half a minute to spin down.
Then I go for a ride, incident free, and get back home and it'll manage maybe 5 rotations before stopping because it's gone off true again! It's knocking at least 100W off my power šŸ˜‰
Any tips - might take my plumbers blowtorch to it and then try straightening. Assume in the oven won't be hot enough. Or just get a new one?
Posted : 17/09/2023 11:48 am
I've got about a 40% success rate with straightening rotars. I've made some worse than when I started.
If I can't sort it straight away I give up and buy a new one.
Posted : 17/09/2023 11:52 am
zerocool reacted
 bens
I think if you get them hot enough and distort them, the metal will always want to spring back to its now deformed shape once it gets hot again.
I reckon get it hot enough again and then bend it back, it'll probably stay true
Posted : 17/09/2023 9:28 pm
Or you'll crack it.
Hydraulic press might flatten it again, people with them swore by them back in the day. If you don't have access to one you would be cheaper with a new rotor.
Posted : 17/09/2023 11:02 pm
SRAM do seem to make quite a lot of bent stuff. See my thread on a wobbly GX cassette…🙄
Posted : 18/09/2023 6:46 am
