Whwere can I get a ...
[Closed] Whwere can I get a 14" tube with a Presta valve - for an Islabike?
12 Users
Having right trouble finding a tube for my sons bike. The Schwalbe SV2 is show as fitting a 14 or 16" wheel but it is far too big. None of my local shops have a tube, they are all Schraeder. Anyone on here bought one anywhere?
Posted : 30/06/2012 11:20 am
Drill the rim for the larger valve....done it on a few MTB rims very easily, deburred and all is fine.
PaulD
Posted : 30/06/2012 1:04 pm
It appears that SJS do them but the postage is usually pretty steep.
[url= http://www.sjscycles.co.uk/michelin-michelin-14-6am-normal-length-presta-tube-14-x-1-1-4-1-3-8-350a-32-37-x-288-prod3815/ ]http://www.sjscycles.co.uk/michelin-michelin-14-6am-normal-length-presta-tube-14-x-1-1-4-1-3-8-350a-32-37-x-288-prod3815/[/url]
Posted : 30/06/2012 1:08 pm
Shirley Isla
Posted : 30/06/2012 1:59 pm
I got one from my LBS.
Posted : 30/06/2012 2:35 pm
I drilled out the rims on my nephews CNOC 14 and fitted shrader tubes plus slime.
Alternatively i may have the old presta tubes in my garage, drop me an email if interested.
Posted : 30/06/2012 4:57 pm
Why the hell anyone uses Presta valves in the first place is beyond me.
As Paul D says. Drill it out. Although I can't imagine it's not already the right size anyway on a kids bike.....
Posted : 30/06/2012 5:47 pm
Presta on every bike here .It comes from riding road bikes before mtbs in the 70s and not wanting to mess about changing pump ends all the time.Also BSOs always have schraeder so I cant use them.
Posted : 30/06/2012 5:53 pm
Sorry just checked and the tubes i have are schrader.
Posted : 30/06/2012 6:57 pm
Too big?
I've fitted the 14"/16" SV2 from Isla Bikes to a Cnoc 14 easily enough.
Fawkes cycles also appear to stock them:
http://www.amazon.co.uk/Schwalbe-SV2-inch-350A-Presta/dp/B004NOGPR6
Posted : 30/06/2012 7:14 pm
Thanks all, I'll try SJS then. Don't really want to drill the rim, and I'd have to buy another tube anyway.
The SV2 is definitely too big, there's a whole bunch of excess rubber that just creases up when I inflate the tube inside the tyre - there's nowhere for the excess to go. Unless I am missing out on a trick, I can't see how it could possibly fit.
Posted : 30/06/2012 7:23 pm
PeterPoddy - Member
What's wrong with Presta? Work fine for me.
Posted : 30/06/2012 8:42 pm
 JoeG
You can use a larger size tube if you have to. [url= http://www.bikemag.com/videos/mechanic-mondays-21/ ]How it is done.[/url]
Posted : 01/07/2012 4:24 am
Not much, but then there is nothing wrong with Schrader either. You have bigger issues if you need to run 100psi on a mountain bike.
If you can fit them drill them and never be stuck with the "I can only use a presta" problem. Nothing more dumb than trying to blag a tube on a trail and turning down the first 15..... (went home and sorted wheel after that)
Posted : 01/07/2012 5:20 am
You can use a larger size tube if you have to. How it is done.
That, is genius. And I've just wasted another fiver on another new tube!
Posted : 01/07/2012 5:28 am
Ahh. That old chestnut.
Tell me, what valve does an air fork or shock have on it, and what pressures do they go up to? 🙂
Posted : 01/07/2012 6:29 am
Presta for me. Never had to blag [i]anything[/i] "on the trail". I have ridden with people who don't carry the right spares for their bike and even didn't carry the right pump. Dumb's the word.
Posted : 01/07/2012 6:57 am
Peter
In the schrader camp here, the only reason people ever give is pressure. Same argument different reason...
Shifter
Grabbed spare wheel (gf's) and got flat. No repair kit and no presta tube, got home got out drill. Had mates on presta only rims having a bad day trying to fix tubes on a crappy day when we all had schraders
Posted : 01/07/2012 12:15 pm
Fairy nuff but I honestly don't have any mates who ride Schrader. The only bikes I've seen lately with Schraders are my 3 year old's and the butcher's bikes we use at work!
Posted : 01/07/2012 2:28 pm
I just tried the method in that video, and it worked a treat. Anybody want a spare 14" presta tube?! 🙂
Posted : 02/07/2012 8:44 pm
