who is running XT 2...
[Closed] who is running XT 2x11 with 11-42 Cassette? any issues?
6 Users
as above really,
done a search but not much coming up that's not 5+ mths old.
Just like to see who is running that combo and if there been any issues,
chain line/noise that I see might be a issue.
GSG rear mech or SG,
As shimano say 11-42 is for the 1x11 set up, just can't see why it should not work with 2x11 set up?
be good to get some feedback.
Thanks
Posted : 22/01/2016 6:00 pm
Why? You can't possibly need that range.
Posted : 22/01/2016 6:10 pm
I could as so unfit at the mo!
But not for me, some one who like riding off road in the alps with kit strapped to the bike, so what's lowest gears with a double.
but also interested in any feed back etc.
Posted : 22/01/2016 6:23 pm
I'm assuming that there's an issue with rear mech capacity that prevents the 42 being used with a double up front. My 2x11 runs fine with the 40T cassette.
Posted : 22/01/2016 6:38 pm
Sure it will work on the 42T, think it might not take up the chain slack when in small chainring and small cogs at the back, but should be to much of a issue if you know how to use gears.
Just wondered if anyone was running that combo to confirm or deny my thoughts.
Posted : 22/01/2016 10:00 pm
The cassette is a massive weight penalty over a decent 10sp. The current spacing on the stock front rings is smaller than on 10sp so not sure of front mech capacity and how that impacts overall.
Probably worth doing the gear calcs to see if it is actually much lower.
Posted : 22/01/2016 10:06 pm
I think the mech doesn't have the range to run a double with the 11-42.
I've got the double with 11-40 and is plenty wide enough range.
Posted : 22/01/2016 10:14 pm
well the rear SGS mech has the capacity (47T) and I am after 41T,
The GS cage is 39T so only 2 out, so I would say that would work also, just have a slack chain in the small small combo, and the institutions say not to use that combo anyway and the rider is switch on not to use it.
Like I said just wondered if anyone tried it yet!
Posted : 23/01/2016 9:44 am
Not being able to run small small is now loss or even the next sprocket or so
Posted : 23/01/2016 5:27 pm
